Trickflow 220/224 cam for turbo?
Old Jun 18, 2007 | 08:24 PM
Mr.MartyStone's Avatar
Default Trickflow 220/224 cam for turbo?
Hey guys, getting my parts together for this turbo build and realize that my 233/239 on 112 TSP cam ain't going to cut the mustard...
With that said the Trickflow 220/224 on 112 lsa (don't recall icl) cam looks to be a great choice. I know people constantly regurgitate the reverse split mantra on here but I can pick one of these up for close to the price I'll get for my used cam. It has -2 degrees of overlap and looks like it will still be small enough to be fun when I'm not in boost (which will be rare I'm guessing )
Car will be a 346/TH400 with a custom ST80 front mount 6.0L manifold kit. I will be running this thing @ around 10 psi until I go forged shortblock, then I'll be running 16-17 lbs or so. Let me hear your ideas.
Thanks,
Marty
Old Jun 18, 2007 | 08:43 PM
Slowhawk's Avatar
LS1Tech Sponsor
It'll work decent but not optimal.
Old Jun 18, 2007 | 08:50 PM
What would you suggest then? I'm not trying to go too big. Should I look for a used Z06 cam on the boards then?
Marty
Old Jun 19, 2007 | 09:54 AM
52172's Avatar
no one really knows the ideal turbo cam. EPP uses one that no one would think would work great. Speed incs uses a 225/225 115 I am using a 222/224 114 NA cam and made 600 rwhp with only 348 cubes at only 9 lbs boost so yes that cam will work pretty good.
Old Jun 19, 2007 | 12:37 PM
Yeah I saw the EPP cam (232/240 on 115) and they had great success with smaller cubed TT setups. Have you tried to turn the wick up anymore on your setup or only runs at 9 lbs? I am curious to see what that TC76MPS will do. I thought I would max it out fairly quickly, thus wanting a ST80, but 600 rwhp at only 9 lbs sounds like there is still a lot left.
Thanks,
Marty
Old Jun 19, 2007 | 12:49 PM
52172's Avatar
I havn't turned the wick up anymore yet. The motor is brand new right now. The numbers it made was impressive. I have talked to DrTurbo in regards to the limits of my TC76MPS and they should be around 850 rwhp on race gas with 348 cubes. So only if you plan on going higher than 850 rwhp then you should save a little money and get the TC76MPS. I drove the car with 600 whp and don't really see a need to turn up the wick right now. They did not even do a full pull to redline it made those numbers at only 6000 rpms I have the redline set a 6500. Hope that helps your decision. How much power do you wish to make once you are forged?
Old Jun 19, 2007 | 01:07 PM
I don't really care how much power it puts to the rollers (TH400 car) I would just like to run 9.60's @ 14X on good gas. I have looked at all the calculators, they all say 750 rwhp but I don't really know what it will take to put a 3200 lb raceweight car to run that number with a turbo setup.
Thanks for your response and hopefully you figure out your smoking issue.
Marty
Old Jun 19, 2007 | 01:13 PM
52172's Avatar
Thanks! We gave the turbo back to Turbonetics and hopefully they find a faulty seal. We could not think of anything else that would cause such a bad smoking problem. It has to be the turbo. For you I would probibly spend the extra 500 bucks and get the ST80 since you are shootin for 9's, but might want to discuss it with Jz and DrTurbo first though. Good luck!
Old Jun 19, 2007 | 02:09 PM
SonofaBish's Avatar
my car is being finished this week... i went with a 220/224 on 115
i wanted bigger, but this cam seemed liek a good choice as to not go too big, but still make good power.... i don't even have the car together adn i wish i had gone with a little bigger cam... but o well... maybe down the road
Old Jun 19, 2007 | 07:31 PM
I have pm'd DrTurbo with no response. I think I will try again today. But my brain got to thinking (stupid brain) why not go with the TC76? If you build up a forged motor you'll go big anyway, so a 43X or 44X would gladly push a pair of TC76's. I already have it bad man, everytime I tell myself that 9.60's is good enough, another part of me says why not 9.20's, or hell till you get kicked off the track at 8.49? This bug is addicting
Old Jun 19, 2007 | 09:16 PM
engineermike's Avatar
I'm at about 3750 lb, and making 695 rwhp, I pulled 146 in the quarter. With only 3200 lb, you're only going to need about 600 rwhp with a TH400 to get those times.
Mike
Old Jun 19, 2007 | 09:20 PM
Dude, there is NO WAY I would take that 233/239 cam out! All the data that's out there suggests that big cams make bigger power in turbo setups. The data also says that more overlap = more power. I challenge anyone to find dyno results indicating otherwise.
INTMD8 did alot of cam testing on his twin turbo LT1 and everytime he added overlap, it gained power. He also tried a reverse split and threw it in the garbage.
Also, there was a GTO a while back with a single T76. It made over 600 rwhp with low boost (6 psi?) with a big cam like yours. I'll see if I can find the post. . .
Mike
Old Jun 19, 2007 | 09:24 PM
SuperZ's Avatar
I run a 220-224 114 with 551 lift.It works great
Old Jun 19, 2007 | 09:52 PM
Okay, found it:
https://ls1tech.com/forums/forced-induction/678711-my-04-gto-76mm-set-up.html
346 cid, TSP heads, 232/234-112 cam, T76, 6 psi boost: 640 rwhp
That cam isn't too far from your 233/239 and he made astounding power with only 6 psi boost.
Mike
Old Jun 20, 2007 | 03:36 PM
52172's Avatar
those numbers are soo high because its a 440 ci motor, but those big cams doooo work.
Old Jun 20, 2007 | 06:19 PM
It's not a 440. It's a 346. It made 440 rwhp on motor before he added the turbo.
Mike
Old Jun 20, 2007 | 07:23 PM
Originally Posted by engineermike
Okay, found it:
https://ls1tech.com/forums/showthread.php?t=678711
Mike
Well crap, I might stick with this cam a little longer. It did go 420 rwhp on two different dynos in a 98...can't be that bad huh?
Old Jun 21, 2007 | 12:21 PM
Cool man, I look forward to seeing your results.
Marty
Old Feb 27, 2019 | 11:41 PM
Ford_Assassin's Avatar
Another run at the top.....a decade later.
Old Mar 1, 2019 | 09:06 AM
JoeNova's Avatar
Restricted User
But why?
