Procharger leaking oil?
Old Jun 30, 2007 | 04:21 PM
Optimus_Prime's Avatar
Default Procharger leaking oil?
I went in to get my oil changed and the guy in the pit said I had some oil on the bottom of my procharger and he couldnt tell where it came from...Is this something to be concerned about?
Old Jun 30, 2007 | 06:15 PM
kp's Avatar
kp
Its normal to get a little seepage. If you have the vent hose connected to the bottom of the inlet hat a little oil will collect on the bottom and leak through since there is no seal where the volute attaches to the case. When you shut the car off when its hot there is also some pressure and a little oil will find its way out from inside as well. As long as its not leaving spots where you partk it or couting under the car I wouldnt worry about it too much, just check the oil in the blower once in a while and change it when you are supposed to.
I always take the oil I drained out and pour it back into the bottle I filled it with, if a lot is missing then worry about a leak
Old Jul 1, 2007 | 01:29 AM
I'll try that, thanks for the advice.
Old Jul 18, 2007 | 08:10 PM
Whitez406's Avatar
Mines doing the same thing. I think mines getting bad tho. lol i think the stock motor is getting some blow by or something. Time for a forged bottom end i guess.
Old Jul 19, 2007 | 07:31 AM
WHPLASH's Avatar
Mine does it too. Usually after the oil is changed out. Never drips. Just collects a little at the bottom of the blower. I think its the oring leaking at the dipstick.
Old Jul 19, 2007 | 08:50 AM
Whitez406's Avatar
Mine doesnt leak charger oil its motor oil. Its pulling it thru the valve cover. I think the motors getting some blow by or maybe it broke a ring.
Old Jul 19, 2007 | 09:47 AM
WHPLASH's Avatar
Do you have a valve cover breather? I put one on and under WOT it gets saturated and drips on the header. Smokin'
I put back on the regular oil cap.
Old Jul 19, 2007 | 11:51 AM
Whitez406's Avatar
Its not the breather thats clean put the vaccum line from the blower hat to the valve cover is where its pulling it from. I think it originally went to the throttle body.
Old Jul 19, 2007 | 12:24 PM
Spade's Avatar
I get sepage from mine as well. EPP told me this is normal for the prochargers. I would not worry about it unless its puddling.
Old Jul 19, 2007 | 01:34 PM
Superado's Avatar
11 Second Truck Club
a lil' here as well...
when changing blower oil, I started pulling mine out from the fill hole with a syringe instead of fighting w/ getting to the drain hole...
Old Jul 19, 2007 | 01:44 PM
Whitez406's Avatar
The top hose is a pain in the ***. I cant ever get the bottle by it.
Old Jul 19, 2007 | 03:22 PM
Mark98SS's Avatar
Mark98SS TechTip:
Put a short piece of rubber hose on the bottle & about a foot of aluminum tube on the hose & you can get the new oil in the top of the head unit with out any mess.
Old Jul 19, 2007 | 03:29 PM
Whitez406's Avatar
Originally Posted by Mark98SS
Mark98SS TechTip:
I never thought of that.
Old Jul 19, 2007 | 05:07 PM
Mark98SS's Avatar
Old Jul 19, 2007 | 05:11 PM
Mark98SS's Avatar
And don't feel bad, the 1st time I changed my oil I removed the head unit from the car because I couldn't figure out how the put the oil in with out removing that water pipe.
Old Jul 20, 2007 | 06:10 AM
Whitez406's Avatar
I did that also
