Ohio Boost System
Old Jul 2, 2007 | 01:36 PM
94m6Z28's Avatar
Question Ohio Boost System
ive been looking at this system for my lt1 camaro, and i think its going to be the way i go, or one like it. my question is...where does it get the oil feed to the turbo from? becuse as far as i can tell the kit dosent have a pump with it. this is probly a dumb question but im curious
Old Jul 2, 2007 | 01:55 PM
1INSANEGTO's Avatar
There is one forsale in the forsale section. And do a search on OFI before you buy
Old Jul 2, 2007 | 02:16 PM
Kanes2413's Avatar
i already sold the car so the kit isnt forsale anymore. Good kit but better update everything else on the car otherwise is non stop headache so ENJOY!
Old Jul 2, 2007 | 02:25 PM
BADDLS1SS's Avatar
I have the LS1 kit and it goes into the front lip of the oil pan, its almost level with the outlet on the bottom of the turbo... Im not sure what the LT1 kit looks like but the turbo sits pretty damn low on LS1's and draining could be an issue if its gotta go up hill at all. being LT1s have rounded steel pans im not sure where it could plumb.
Good question to ask though!
Old Jul 2, 2007 | 05:49 PM
otherwhitemeat's Avatar
you can get oil to the turbo from the oil sending unit behind the intake manifold. just pull it off and go to the hardware store and make it into two ports.....easy
Old Jul 2, 2007 | 06:41 PM
RealQuick's Avatar
Right above the oil filter is a 1/8NPT hole (remove plug) for the oil feed.
Old Jul 2, 2007 | 06:45 PM
94m6Z28's Avatar
thanks, i was just cruious becuse when i go for it im gunna nuke the oil cooler and and i was thinking they might get it from there some how
Old Jul 2, 2007 | 08:03 PM
RealQuick's Avatar
I believe its actually on the block, so cooler or not, it doesnt matter.
