APS boosted 402 dyno results (7psi)
Old Jul 12, 2007 | 11:19 AM
  #41
Tom@SpeedInc's Avatar
Originally Posted by rufretic
Damn Fraser, thats a torquey sumabitch. Hows it feel on the street? Can you get any traction? I can't wait to see what it does with some more boost. Congrats.
thanks Lou
at WOT no traction for first 3 gears, 4th gear it hooks and goes to warp speed mode
Old Jul 12, 2007 | 07:57 PM
  #42
nanokpsi's Avatar
Originally Posted by pakisho
Its a much bigger motor you knucklehead.
You're right, I have no ideas when it comes to turbo systems
100whp with such a small amount of boost is a big deal. If the compariosn was done at higher boost the delta would obviously be much greater. In fact, if the turbos were capable of it, I'm sure you would see close to a 200whp difference at 1 bar of boost.
Old Jul 12, 2007 | 08:35 PM
  #43
Mr.MartyStone's Avatar
I don't think the delta would be that great. I am also one of the guys who really aren't impressed and think these numbers are OK. Dyno's lie though so you can never tell.
It's a high SCR 402 with Dart heads and Fast intake. N/A it would probably make 485-500 rwhp or so. 7psi is theoretically 46% more power...and you would arive around 710+ rwhp. I would like to see it with more boost as well, hopefully those numbers shut me up.
The install looks really clean...congrats to the owner as it sure will be a blast to drive.
Marty
Old Jul 12, 2007 | 08:49 PM
  #44
peter@aps's Avatar
I dont think this car will make a whole lot more than it is currently making.
I'd bet it will make well north of 800 rwhp with with 16 PSI, meth injection and with a thorough tune.
Peter
Old Jul 12, 2007 | 08:52 PM
  #45
peter@aps's Avatar
Originally Posted by bluecamaroz28
Either way, those are impressive numbers from 7 psi only. Imagine what will happen with say 17 psi.
I agree and I'm sure Fraser has plans to boost up this baby.............he's just getting started and there's plenty left on the table.
Peter
Old Jul 12, 2007 | 09:52 PM
  #46
bluecamaroz28's Avatar
The install looks really clean...contrages to the owner as it sure will be a blast to drive.
Marty
Would never have said it better than this. Exactly what I was trying to say.
Old Jul 12, 2007 | 10:44 PM
  #47
Just a comparison
https://ls1tech.com/forums/forced-induction/678711-my-04-gto-76mm-set-up.html
346cid, TSP heads, 232/234-112 cam, T76, 6 psi boost: 640 rwhp
Old Jul 12, 2007 | 11:35 PM
  #48
Peter
Have an Innovative electric boost controller in stock.
Maybe i'll have to look at installing it. Ramp it up to 14 and see what happens.
This motor wasn't a dyno queen before the turbo system btw, but always made a mountain of torque.
Old Jul 12, 2007 | 11:41 PM
  #49
qqwqeqwrqwqtq's Avatar
I don't think people are understanding why this combination is what it is.
Fraser installed this turbo system onto his existing setup, with the exception of a valvespring and camshaft change, it wasn't designed from the start as a max-effort turbo build.
Personally I am impressed with the setup. Transient response is instantanious and their is no sharp dropoff in power at high rpm, which is what one might expect with larger displacement and turbos that are so responsive.
What would be expected out of a mild 402 and turbos you can fit in the palm of your hand? 1000rwhp at 4psi?
Actually Fraser, maybe the best thing you could do is write a suicide note on the back of your dyno sheet and send your car to Victory Auto Wreckers
Old Jul 13, 2007 | 05:24 AM
  #50
Loud and clear, not a max-effort turbo build is the word.
I say it for the 3rd time, those are great numbers and sorry if my responses offendend anyone of Speed Inc.
Old Jul 13, 2007 | 08:58 AM
  #51
RealQuick's Avatar
Marty
635-485 = 150
150/7 = 21.4 rwhp/# of boost
Seems reasonable to me.
Old Jul 13, 2007 | 03:53 PM
  #52
Bryan @ Speed Inc.'s Avatar
this car idles like stock... it's very quiet, pulls like a ******* freight train from the moment you crack the throttle.
this is one quick car for having a 4200lb raceweight. i'd love to be able to duplicate that on my car. Thumbs up!
Old Jul 13, 2007 | 04:37 PM
  #53
Anyless of a person would have burned this car by now.
Old Jul 13, 2007 | 04:38 PM
  #54
Originally Posted by RealQuick
635-485 = 150
When did I say it made 485? (NA)
Old Jul 13, 2007 | 04:48 PM
  #55
i think he meant it SHOULD make that number... but not with such a tame cam, and through full exhaust.
some people just don't get it. it's a 402 = should make 500+ rwhp right? add 2 turbos - that's 200rwhp more PER TURBO right?
it is what it is - 100% streetcar with stock driveability.
Old Jul 13, 2007 | 05:03 PM
  #56
LS1 SPEED's Avatar
This setup is making approx 30 rwhp per pound of boost.
The motor didn't make great power due to throwing it together on Frasers part. The setup NA made 42? rwhp with the NA cam. The car wasn't on the dyno since switching to the 225 Turbo cam....say it lost a few.
based off the above calculation it puts output at over 30rwhp per pound of boost which I feel is pretty good
maybe when it is turned up some of the other can appreciate it more
now lets see if he can drive it down the track tonight
Old Jul 13, 2007 | 05:47 PM
  #57
peter@aps's Avatar
Can't ask for much more than that..................should be awesome on the track.
Peter
Old Jul 13, 2007 | 07:00 PM
  #58
JMBLOWNWS6's Avatar
LOL Anything with boost is going to cost you $. Good job guys
Old Jul 13, 2007 | 07:52 PM
  #59
RealQuick's Avatar
Dont worry about it unless I quoted you The guy I quoted stated you should have been atleast 485rwhp before the turbos. I was pointing out that even if that were ture, you still gained some good rwhp/psi
Old Jul 16, 2007 | 11:48 PM
  #60
peter@aps's Avatar
Hi Fraser, When if at all do you do plan on running a little more boost in your twin turbo GTO? Or is traction already the limiting factor to higher performance?
Peter
