project turbo_z
Looking good btw! im out ofd school for the summer, work has picked up and everything seems to be going good now
i managed to save up a few bones to get the rest of the stuff i needed so here is goes
Glad to see you're making progress again. I'm stuck, only have the down pipe left to make and my welder doesn't have time to come NEXT DOOR and hit it for me.(about 2 hrs of work) About to order HP Tuners this week also.
just tape off your cut line, keep steady pressure on the blade, make sure you dont slip... use a dremel to clean up any imperfections.. i left 2 mounting tabs, but i will most likely cut them off as well.. im going to lower the IC about an inch and a half
i used 2" square tubing, then came off of it with 2 pieces or 3/4" square tubing.. this also allows a little bit of adjustment from left to right so you can center everything up perfectly.. im going to weld it all up after i make sure the IC piping will fit
mount
mount from the front
i just threw on a 90* on both ends and everything fits nicely under the bumper cover.. now i have to wait for my pipes to come back from being coated
im also starting a photobucket album of the install http://s77.photobucket.com/albums/j6...bitch/TURBO_Z/ for all the other people who are installing the same kit as me..
i decided that a vertical radiator was the only way to go to allow the maximum amount of space
i ordered a new griffin radiator from summit yesterday, but the more i thought about radiators i remembered a radiator i had buried in the garage from my old SB GMC Jimmy a few years back. it has the same exact measurements as my new one, so im using it for mock up purposes. i also happened to have 2 12" fans that move 1200cfm each..
here are a few pics (sorry for the low quality pics. my batteries are dead on my digital, so i had to use my cell)
tomorrow morning im going to weld up the ends of the cross brace as well as weld in my new 2"x1" rectangular steel brace to strengthen everything up.. now i have much more room to fit everything in there
EDIT: this did not have to be done, but i decided it would be much easier to access every thing in the future, and now i have a bigger radiator to keep everything nice and cool
i welded in a 2x1 rectangular steel brace to strengthen the section i cut out to stand the radiator upright
i also put in the new radiator and fabbed up a support out of some angle aluminum for the bottom as well as the top
Griffin 1-25241-X
i also installed smokinhawks alternator relocation bracket
mine took a 6rib 73.5" belt. i got mine from advanced auto parts and the PN is 5060735 the last 3 digits of the PN dictate the belt length
Serial # D 6068-04 Spec Card# 06930104
Part # 54-000-11 CAMSHAFT, LS1 CHEVY LS1/GEN III '97-UP
Core C54-11H CAMSHAFT BLANK, LS1 1997 UP 5.7 CORVETTE
Grind # LS1 3724R /3726R HR112+4
DURATION @ .050 INTAKE 228 ROCKER ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 232 INTAKE 1.70
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3460 EXHAUST 1.70
VALVE LIFT INTAKE .588 LOBE LIFT EXHAUST .3500
VALVE LIFT EXHAUST .595 LOBE SEPARATION 112.0
DURATION .006 INTAKE C/L 108.0
TAPPET LIFT INTAKE 277 CAM ADVANCE 4
TAPPET LIFT EXHAUST 281 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 6 JOURNAL DIAMETER STD 2.165
VALVE OPEN EXHAUST 52 RECOMMENDED VALVE SPRINGS
VALVE CLOSED INTAKE 42 DEPARTMENT P
VALVE CLOSED EXHAUST 0 SPC INSTR FOR CUSTOMER
any input would be greatly appreciated. im also going to post this up in the internal engine section
