project turbo_z
Old Feb 12, 2008 | 03:30 PM
  #141
Websy21's Avatar
I agree with the 60's and can be tuned even with a stock car while going upwards to 1000rwhp with the right setup.
Old Feb 12, 2008 | 03:51 PM
  #142
presto_z's Avatar
Originally Posted by smokinHawk
42lb injectors will be good for about no more then 600rwhp, 60's will be good for around 800rwhp so how ever much you'll think you need.
im not gonna be over 500hp so i think i should be fine..
if anyone has any solid motor mounts that they want to get rid of ill buy them (assuming the price is right)
Old Feb 14, 2008 | 06:07 AM
  #143
BigJls1's Avatar
why are you getting a bov with an auto. you dont need it.
Old Feb 14, 2008 | 01:00 PM
  #144
stg747's Avatar
any updates? interested in seeing how this kit works out
Old Feb 14, 2008 | 02:37 PM
  #145
presto_z's Avatar
still highly recommended.. if im at a high rpm and let off the gas, that throttle blade is still gonna close uber fast.. the pressure has to go somewhere
kit isnt on the car, but im sitting at home waiting for the fedex guy to show up with some more goodies
i have everything i need except gauges, and money for a tune and new exhaust.. so hopefully within a month ill be ready
here is another member with the same kit and a new turbo
https://ls1tech.com/forums/showthrea...450&highlight=
Old Feb 15, 2008 | 01:57 AM
  #146
chuntington101's Avatar
presto z, hows your mates corvette holding up with his kit??
Chris.
Old Feb 15, 2008 | 05:16 AM
  #147
presto_z's Avatar
kit piping and turbos were holding up great, but his eletrical.... not so much
i guess this problem is not uncommon with the TT corvette PTK corvette setup, he says if he can get an alternator that actually charges he will go back to the kit without a second thought.. he had to use a tiny *** alternator (as do the PTK vette kits) and it would only charge around 11.5volts at idle
he had about 5,000 miles on the turbos and they didnt smoke, or fly apart..
Old Feb 15, 2008 | 06:44 AM
  #148
thats bad news on the alternator. have you spoke to Nick Yoskin on here?? he has a PTK kit on his vette and is running a 427 ls7 with around 1000bhp. there are a few more guys i can put you in touch with to if you want...
did he/you have some testing done on the pipe work?? is it really 321 stainless steel?? what was the fit like??
cheers
Chris.
Old Feb 15, 2008 | 02:41 PM
  #149
presto_z's Avatar
every thing bolted together perfectly, im not sure about the thickness of piping, its the same thickness as mine, so ill have my welder look at it when he weld on my BOV flange to my intercooler piping..
he actually talked to yoskin about his issue, and he recommended an alternator company to go to..
here is a pic of his bracket and alternator
and here is one next to his stocker
and here it is on the car (well one of them, he had to order like 3 different ones)
he does have a TV, navigation, 2 amps and subs , so im sure that may have contributed somewhat
also has alot of LED's
is yoskins PTK or halltech? either way he has a badass car, i guess thats why he can get away with that huge *** pic in his sig lol
Old Feb 15, 2008 | 02:56 PM
  #150
Reject's Avatar
congrads i wish mine would have, did you find all the v-band clamps?
Old Feb 15, 2008 | 03:09 PM
  #151
presto_z's Avatar
this is my neighbors vette setup from the same company, not mine.. but yeah i found all the vband clamps needed, im still gonna check into those flange bolt holes one of these days lol
Old Feb 15, 2008 | 04:32 PM
  #152
presto_z's Avatar
well here is the latest batch of goodies
UMI 3point sub frame connectors (don't mind the chopper frame.. thats a different project and i didn't feel like moving it)
FORD SVO Greentop 42# injectors
Turbonetics Raptor BOV
Turbonetics Evolution Wastegate
Treadstone Performance Oil feed and return line
Silicone couplers and Tbolt clamps
Snow Performance stage 2 Methanol injection kit
my Racetronix Fuel Pump and Harness should be here in a few days (i had no clue they were from Canada)
i was going to get some spohn solid motor mounts, but decided to go with a new K member with the mounts already on (i hope my stock mounts make it a few months until i get it)
still need some gauges
Old Feb 15, 2008 | 05:04 PM
  #153
ninetres's Avatar
Ebay turbo kit, 60lb injectors for 1k HP, no BOV needed for auto cars.........
this thread is PACKED with riveting information.
/E-THUG
Old Feb 15, 2008 | 06:18 PM
  #154
Black_Jack's Avatar
the pipeing looks good, but i would just be worried about the turbo failling, the a tuning shop here local that has had a lot of problems with the turbos gooing outon kits like this,
but good luck kit looks great
keep the pic's updated as u do the install
Old Feb 17, 2008 | 03:32 PM
  #155
presto_z's Avatar
i got a few more goodies
hotchkis shock tower brace
A-pillar triple gauge pod
Old Feb 17, 2008 | 04:09 PM
  #156
94blownz281's Avatar
looking good can't wait too hear a sound clip of that BOV.
Old Feb 17, 2008 | 10:13 PM
  #157
defaultexistence's Avatar
hey all! just wondering how the install when for yous. i just got done with the complete install of this very same auto power prise hot kit and turbo. i'm super impressed and will be writing my own story here with pic's this week..
Old Feb 17, 2008 | 10:33 PM
  #158
presto_z's Avatar
i want all the details.. the good the bad and the ugly.. and a crap load of pics too.
Old Feb 17, 2008 | 11:00 PM
  #159
No problem!
one fitment issue i ran into is the drivers side hedder..either the first or the last bolt hole is slightly off....so.. i started with the last(farthest bolt first and all line up but the very first hole..so i took hedder back out got a drill widened it and bam! fits,
i wrapped the pipes that criss cross around the driver motor mount with hedder wrap and have had no smoky motor mount as of yet.
i wrapped the turbo(that came with the kit) in a heat blanket type of wrap from advanced auto parts to keep temps down near the back of the radiator (drivers side).
i cut my stock fan shroud unit in half and kept the passsenger fan in place and bought a new one for the front of radiator on the driver side set to push air.
drilled and tapped a return passage w/motor in car
relocating alt bracket -smok'n hawk's here on ls1 tech.
hot wire fuel pump relay and wiring-ebay
fuel pump-ebay
svo green tops - here on ls1tech
small breather filter-advanced a.p.
couplers-ebay
t-bolt clamps-ebay
v-clamps -ebay
universal intercooler piping-ebay
feed and drain lines -ebay
cone k&n type air filter-advanced a.p.
t6 ngk spark plugs- advanced a.p.
pcm4less computer
i've got about 2800 in it total
i've still got a few last details to work out but HEY! i'm currently boosting
pic's soon
-mike-
Old Feb 18, 2008 | 04:18 PM
  #160
put 100 miles on the kit today...didnt push it too hard but used 8lbs of boost several times rolling...acts like the motor is now alive in overdrive
