project turbo_z
Now on to the coating as you can see my whole kit is coated and while it helps a little it really is not going to save you from having to wrap the whole thing. Sorry sad but true and dont skimp on the wrap get good wrap and stainless clamps to hold it on an if you can use their wrap coating too helps keep the moisture out.
hey thanks man.. ill hopefully be able to make it next weekend but we will have to see (depends on how much i spend on other parts this week lol) you took good care of chris and have always been helpful to other members so you will be coating my parts.. i havnt even thought of going someplace else
and thanks for all the help guys, i need all the help i can get on this one
also how much do you want for that turbo?? send me a PM
and I'm not kidding about the solid mount. does it look like there is anyway my kit may be slightly modded where it would fit, or does is it way to tight?
Smokinhawk makes a relocation bracket for the stock alt that works well; send him a PM.
good luck with it.
smokinhawk what size belt do i need for ur bracket, also do i loose anything or have to change other stuff around?
ill order it tonight if i dont loose anything or need more stuff to make yours work (besides a belt if needbe)
EDIT: im looking at piping now, how thick should the piping be 6061 aluminum? 2mm thick??, i really dont know what to look for..
how do i measure v-band clamps.. from outside to outside right??
some are 3"
while others are 3 1/4"
i cant seem to find any 3 1/4" on ebay, all the 3" butt up with other 3" and the 3 1/4" butt up with other 3 1/4" so they arnt mismatched
so let me know if you could.
ohh and the one on the turbo is 3 5/8.. are these things like hose clamps where you get close (within a 1/4") and can tighten down or do they need to be exact..
are they measured with the pipe size
or outside of the flange size???
ill call up PTK tomorrow and see what they say.. they sell 2 1/4", 2 1/2", and 3" for around 25 each.. im assuming these are the ones for their kits, and i have a clone kit of theirs so ill just check with them...
i think i found the intercooler piping, t-bolt clamps and silicon couplers im going to purchase...
i still need to find injectors and a fuel pump (im gonna go with an in tank fp, but im still not sure on how big of injectors i shud get)
i also need a BOV (are the ebay ones good enogh to run) they seem like a simple design..
im not takin a chance on the turbo or wastegate, so that should be all ill have to purchase after this weekend... ohh and i need some gaskets, but thats no biggie
Verocious Motorsports carries a large selection a V bands and ships fast, google it.
J
Thats a pretty good looking kit. If you want to run it without a tune like you said earlier, you just need to remove the WG spring and run the car as normal. It wont make any boost. Do not run it with open pipes. You don't want unfiltered air or objects getting into the TB or inlet of the turbo. I have a T60 that would spool up real fast for sale if your interested. Its got a 3.5" vband though. 60-1 wheel, P-trim, .70 comp. PM if your interested or click the link in my signature.
Goodluck on the install and post some pics!
ohh and i was gonna call up pts just to see how vclamps are measured (still havnt gotten a strait answer and ive searched a few sites) i think i can get them a little cheaper.. 200 bucks in vband clamps seems a little high to me.. im sure i can do better soomeplace else (ill google Verocious Motorsports thanks)
for the belt for the alt bracket its usually around a 73.5" belt (don't know for sure until its done, but going out here in a sec to make one or two up). nothing else really changes when relocating the alternator, you just have to reroute a couple of wires, and extend the small gauge wire, i think.
for the BOV it needs to be before the maf, unless you route it so it blows off after the maf, then recirculates after the maf, its alot easier to just put it before the maf and dump it out in the atmosphere.
