project turbo_z
Old Jul 14, 2007 | 09:03 AM
  #61
nossty1's Avatar
I have the PT% kit and the only problem I had was wait time. It can def support some power.
Old Jul 14, 2007 | 03:34 PM
  #62
presto_z's Avatar
Originally Posted by smokinHawk
for the belt for the alt bracket its usually around a 73.5" belt (don't know for sure until its done, but going out here in a sec to make one or two up). nothing else really changes when relocating the alternator, you just have to reroute a couple of wires, and extend the small gauge wire, i think.
so i re-use my factory alternator then?? ive noticed some kits require a new one
what about one for a ls1 vette??
Old Jul 14, 2007 | 06:30 PM
  #63
smokinHawk's Avatar
one i have keeps the stock alternator.
havent ever done one for a vette since the pulley is further in and i dont have a vette to make one to.
Old Jul 15, 2007 | 03:39 AM
  #64
presto_z's Avatar
to bad about the vette one but payment was sent for mine... i also purchased all the intercooler piping today and some goodies at the hardware store...im gonna order a few more things tomorrow.. i wanna start this thing asap
Old Jul 15, 2007 | 07:48 PM
  #65
presto_z's Avatar
should i ditch my 3.73's and go back to my 2.73's.. i have a 3600vig stall, so traction is a major issue right now, i can just imagine under boost how nonexistent it will be.. plus i miss cruisin around at decent rpm's...
im also looking at a turbonetics raptor BOV ($199), and a turbonetics evolution wastegate($219) is this fair pricing?? this stuff ads up fast lol
Old Jul 15, 2007 | 08:48 PM
  #66
frcefed98's Avatar
LOL it sure does. Nothing about FI is cheap...you'll see.
Go to a 3.42, but a 3.73 will work.
Start looking for a new converter or send that one back to PI and tell em what you are doing and they'll set you up.
Old Jul 16, 2007 | 07:47 PM
  #67
n2oJOE's Avatar
well my kit just arrived my biggest isssue was going to be the oil system for the turbo. i wanna keep this build fairly simple, so i ordered a sandwitch for the oil cooler to feed the turbo. now is the return....ugh. well i didnt wanna drop the pan and the k member and weld in the bung and fitting and im nut gonna do it in the car. so i figured one better im gonna install the return to the back of the valve cover and weld it in. worst case i figure ill have to install a pump to flow the oil higher then the turbo. i dont wanna have to much pressure on the turbos oil seals. also im lookin into the v-bands im gonna find the best deal on these. -N2OJOE
Old Jul 16, 2007 | 07:54 PM
  #68
Superman09's Avatar
LS1Tech Sponsor
Take the time and drop the pan and have it gravity drain. Pumps are a PITA and make it much more complicated...
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Jul 16, 2007 | 09:59 PM
  #69
n2oJOE's Avatar
well im not sure if i am going to need a pump. i think i will though, also the sts kit plums the return into the plastic oil fill cap i think in the back of the valve cover will work ok for me also
Old Jul 16, 2007 | 10:46 PM
  #70
presto_z's Avatar
let me know where you get the vclamps from.. i need to order some still..
Old Jul 16, 2007 | 11:01 PM
  #71
Superman09's Avatar
LS1Tech Sponsor
well if oil flows uphill in your part of the country, let me know and i'll come there so i can ditch my pump. No way you can return it to the cap without a pump, oil will only flow downhill. Yes, same as STS... a lot of people are fine with the STS oil, some have issues, mainly its the custom kits with pumps that have issues, like i did. You will need a pump to return to oil cap, and make sure you MUST run a check valve in the feed line, otherwise you will have issues. Hope this helps...
__________________
Old Jul 17, 2007 | 12:15 AM
  #72
n2oJOE's Avatar
yes that helps any info is good info. what kinda pump are you using?
Old Jul 20, 2007 | 05:26 PM
  #73
presto_z's Avatar
well pieces are coming in little by little
i got smokinhawks alternator relocation bracket and holy **** this thing is sturdy, my alternator shouldnt move anywhere (my camera batteries died before i got a chance to take some pictures of it)
but i did get pictures of my intercooler piping, its 3" aluminum piping 2mm thick, it came with seven 3ply silicone couplers and 16 stainless t-bolt clamps
i got paid today, so ill be ordering more goodies this weekend
Old Jul 20, 2007 | 05:34 PM
  #74
Whistler's Avatar
Sawzall and Welder Mod
Looks good. You're getting close!
Old Jul 20, 2007 | 05:39 PM
  #75
presto_z's Avatar
hey, you think you might be able to squeeze me in next weekend??
i wanna get this stuff coated soon
let me know..
thanks
Old Jul 21, 2007 | 08:22 AM
  #76
Whistler's Avatar
No problem. Just give me a call. Chris has my cell to reach me direct.
Old Jul 21, 2007 | 01:59 PM
  #77
presto_z's Avatar
ok thanks alot... his install is almost done, he is just waiting on a few parts to show up, and a tune
and ill bring all the goodies for you to check out..
thanks
-steve
Old Jul 21, 2007 | 02:43 PM
  #78
Dragframe's Avatar
wish they would have copied the lt1 kit. lol...
can't wait to see how it all works out for ya i the long run. The headers on my lt1 set-up are SSAC and they look like they are good quality... and the stainless welded decent... so
Old Jul 22, 2007 | 12:43 AM
  #79
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Paydays are the best! I'll be ordering parts for mine soon too.
Old Jul 22, 2007 | 09:23 AM
  #80
gator's 99TA's Avatar
presto, give fernando a call at TP about the turbo stuff. he has access to turbo stuff as he has built a few kits himself
