F.I. SYNTHETIC OIL BLOW BY ?
GOT THE CAR OUT FOR THE FIRST TIME TODAY,
IT RUNS STRONG BUT BEFORE I GOT IT TUNED
I PUT 5W-30 FULL SYNTHETIC IN IT
AND NOW IM GETTIG SOME BLUE SMOKE AT FULL THROTTLE
DO YOU THINK I SHOULD PUT SOME THICKER WEIGHT OIL IN IT
OR ARE MY RINGS HEADED SOUTH
IM ONLY SEEING 3LBS OF BOOST DUE TO SLIPPING BELT
ANY INFO WOULD BE COOL
THANKS
THANKS
With forced induction you might want to try out Redline 10w40 or Amsoil 10w40, both of which should reduce your oil consumption.
THANKS
THANKS
www.candsspecialties.com
You will have to have a bracket made to hook it up to your motor. I've been toying with putting this on my mostly stock 99' Z28 1LE, just to see how it would really wake up the engine, and go well with the low drag rings the LS1 uses. Moroso also sells a nice pump.
www.moroso.com
Here's a place that sells race grade sythetic oil. I use 0w-5. It is a really low drag oil, that has a high flash point, and doesn't burn, but it's $10qt.
www.neosythetic.com
