boost level not returning after shift...
Old Jul 21, 2007 | 10:33 AM
Superado's Avatar
11 Second Truck Club
Default boost level not returning after shift...
boost usually climbs to 10+ #'s...drops to 5-6 #'s @ 1-2 shift...then climbs back to 10+ #'s...(TB converter)
last night:
boost climbs to 10+ #'s...
1-2 shift...drops to 5-6 #'s...
boost then only climbs back to around 8 #'s...
changes from last tuning session:
smaller tires...30" street tires to 26" MTDR...have always run these though...when tuned last w/ street tires, tune was changed to shift by rpm instead of mph...which should have eliminated the need to change tune to run the smaller tires, correct?
93 octane to 110...if too much octane, it could decrease power but not boost level, correct?
changed tires back to 30" street tires...filled up w/ 93 on the way home...SAME TUNE...stopped...went WOT...boost climbed to 10+...1-2 shift dropped boost to 5-6...then it climbed right back up to 10+ before letting out...
Old Jul 21, 2007 | 11:21 AM
jaydubb's Avatar
I dont own a Procharged car, but I do own a Roots-blown car (1998 GTP)...
I've only seen the boost drop on my car while WOT 2 times. Once when the bypass valve control solenoid went bad, and the other when the blower belt unexpectedly began to shread. I put a belt on it the week before (cheap Autozone crap) and it began to fail in the middle of a street "encounter".
Imma take a guess and say belt-slip, maybe? Thats where I would start. Since I dont have a lot of experience with centrifugals, I might be way off the mark.
Old Jul 21, 2007 | 10:34 PM
Superado's Avatar
I understand your answer based on your experiences, but it doesn't do it with the taller tires and 93 octane...or hasn't I should say...before AND after doing it at the track on 26" tires(which I've ran several times w/o issues...including my best ET) and 110 octane...
Old Jul 22, 2007 | 12:19 AM
2002/Black/SS's Avatar
could be gearing. u go thru the gear too fast with the 26s so it dosent have time to build boost. u might need a smaller pully
Old Jul 22, 2007 | 11:24 AM
jaydubb's Avatar
Im totally confused... LOL!
Old Jul 22, 2007 | 10:51 PM
Superado's Avatar
ditto...
Old Jul 23, 2007 | 02:50 PM
alwaysinboost's Avatar
First off, how are you measuring boost? is it thru a MAP sensor or by the old eye ball method?
Second, have you ever done a boost leak test? If not that would be the first place you should check.
Tire size & octain rating have zero effect on changing the amount of boost you are making so I don't think they are factors. With a SC, your boost is fixed so you should always be making Xpsi @ XXXXRPM. the exception to this rule would be if you have a boost leak.
I've never experienced belt slip first hand but I would *guess* that if your belt is slipping, in 1st gear it would be the most obvious because the engine is spinning the fastest.
Old Jul 23, 2007 | 02:59 PM
HUNTER02SS's Avatar
I would have to say due to the smaller tire it is not having time to build up the boost because it go's thru the gear so quick. My supercharged camaro I had did the same thing.That would be my guess?
Old Jul 23, 2007 | 03:08 PM
wannasupra's Avatar
i'd say either belt slip (makes sense) or possibly your bypass valve is opening?
Old Jul 23, 2007 | 03:10 PM
cablebandit's Avatar
when he gets here with the DRs on, we are gonna test it at the local test strip
