View Poll Results: is meth injection a power adder
Yes it is a power adder
14.42%
No it's not a power adder
74.04%
Needs further discussion
11.54%
Voters: 104. You may not vote on this poll
Is meth considered a power adder
Old Jul 27, 2007 | 11:18 AM
  #61
wickedwarlock's Avatar
Originally Posted by engineermike
[hijack]1320, I work downstairs from a bunch of fuels blending chemists. Talk about get more info than you ever wanted. . . Anyway, I didn't write down energy contents during this conversation, which was over a year ago, but I do remember concluding that summer vs. winter fuels had a larger energy difference than 87 vs. 93 octane.
All theory aside, I kept 2 magazine articles proving this to be true.
Hot Rod, December 2001, "Octane Shootout"
Engine: 360 Chrysler, 10.4/1 compression
87 octane: 396 hp
91 octane: 402 hp
114 octane: 408 hp
Timing was adjusted for max power on each fuel. The 87 and 91 both made best power at 36 deg timing, while the 114 did best at 31 deg. This is not a typo. From the article, "we discovered that our presumption that higher-octane fuels burn slower than lower-octane fuels is largely incorrect. There are too many other fuel-fomulation issues at work to assign a general rule about octane."
Hot Rod, January 2004, "The Full Scream"
Engine: 408 Chevy, 9.9/1 compression
91 octane: 637 hp
114 octane: 651 hp
From the article, "It was evident from plug inspections that the engine was not experiencing detonation on the pump gas. . . our increase on power was more likely due to the fact that the structure of street gas includes hydrocarbons that may not vaporize until 400 deg, whereas the race gas vaporizes at perhaps 275 degrees."
[/hijack]
Mike
Tell that to Texaco, they did a study on fuels back in the early 90s. Fact, higher octane fuels burn slower under same car conditions. So moving, timing, etc would affect how fuel is burned but not under the same conditons. It's been awhile, I'll see if I can dig it up.
Old Jul 27, 2007 | 11:24 AM
  #62
Originally Posted by great421
Given that line of reasoning, then ice on the intake is a power adder too, because of the same cooling effect.
Don't misunderstand, that is NOT a flame on you andereck, I'm just driving a semi-truck thru the hole in that particular line of reasoning.
I'm leaning towards onfire on this one, as it does not add O2.
Oh and I use Meth (blended 50/50 with water) on my normally aspirated LT4 (I still have not got that STS kit installed!); does it "add power" YES!
Should it be classified / regulated as a true Power Adder like turbos, nitrous, and superchargers? I don't know...
But I do know this, if it is considered a stand-alone Power Adder, then Intercoolers should be too, as they perform the same function.
You can't get any extra power without tuning. Same applies to race gas. Same thing applies to an intercooler.
They all require additional tuning. I say "No" to being a power adder. Otherwise, just as everyone else has said, than you need to ban them all, no race gas, no intercooler, no meth.
Old Jul 27, 2007 | 11:29 AM
  #63
nmp27's Avatar
Didnt look to see if it was already posted, but I think the LSX shootout rules said something about it being prohibited in certain classes..
Old Jul 27, 2007 | 11:30 AM
  #64
engineermike's Avatar
You DO realize that octane and burn rate are not completely dependent upon one another, right?
First, in both tests I quoted, a chemist from Unocal was contacted about the results, and he agreed that they are as expected, then explained why.
Second, I work at ExxonMobil's 2nd largest refinery (~500kbbl/day). I can very easily get all the numbers (and had them before, but didn't keep them). However, I'm off on vacation until August 6, so it'll be a while.
Mike
Old Jul 27, 2007 | 12:53 PM
  #65
Mike
It's all good, just referencing the article I read about 10 years ago. It was posted in a small book inside of motortrend on how to save fuel or something. It talked about it's better to turn the car off if your running in the house for more than 45 seconds because your wasting gas. It covered that kind of stuff. Certainly an interesting article when the gas prices started rising.
I'm pretty certain it was a Texaco document.
I got a brotherly friend. Well, a friend that I call a brother. His dad works for Chevron, 30 years or more now, damn. I could pull them too I guess.
In all honestly, doesn't matter to me, rofl. Hey, have a good Vacation. I leave the week your coming back.
EDIT: Interesting article: http://www.state.mn.us/mn/externalDo...ctaneFacts.pdf
Old Jul 27, 2007 | 01:02 PM
  #66
I think your right. Can only run certain size turbos too in some other classes. The rules are getting too deep, rofl.
Old Jul 27, 2007 | 01:20 PM
  #67
great421's Avatar
Default They all require additional tuning?
You can't get any extra power without tuning. Same applies to race gas. Same thing applies to an intercooler. They all require additional tuning.
WW -
I don't want to sound agruementative, but the automotive PCM is an amazing contraption and it will adapt internally (i.e. - self-regulate / self-tune) on it's own; for example: I can run on 87 or 93 octane fuel without a 'new tune'.
I can indeed get 'more power' just by activating the Meth system on my car; how much more? I have not done a Dyno before / after comparison so I don't have any dyno graphs to post, but it feels / acts / runs stronger and displays other indicators of more power... (Better ETs, Higher Trap speeds, more damamge to my 10 bolt!, etc...)
Having said that, is it 'optimized' without a tune? No, not at all. But, denser, colder air / more O2 = More Power, regardless if the PCM is externally tuned to take FULL advantage of that extra O2.
If tuning was truely a requirement after every mod, we'd need to do it after adding a K&N air filter!
Old Jul 27, 2007 | 01:24 PM
  #68
WW -
I don't want to sound agruementative, but the automotive PCM is an amazing contraption and it will adapt internally (i.e. - self-regulate / self-tune) on it's own; for example: I can run on 87 or 93 without a new tune.
Having said that, is it 'optimized' without a tune? No, not at all. But, denser, colder air / more O2 = more power, regardless if the PCM is externally tuned to take FULL advantage of that extra O2.
I agree, but even putting in 100 octane fuel won't necessarily give you more power. Sure it will adapt some, but nothing to say it's an advantage.
Same applies to an intercooler. Just because the air is cooler doesn't mean I will get more power. The cooler air allows you to run more boost. That's where you get the more power from. Just like fuel, you get the extra power from advancing the timing some.
PCM adjusting or not, won't give you an advantage. If it gained 10% more power, possibly, but I haven't seen any yet gain that kind of power from any without additonal tuning.
try running the car on the same day under similar conditions. Post some time slips. They are not going to be night and day difference.
You will see your biggest gains when you tune the car for 93 octane with the meth. But, I'm not buying the seat of the pants changing without a tune.
Old Jul 27, 2007 | 02:30 PM
  #69
MIGHTYMOUSE's Avatar
if race gas is allowed in the class then meth should be allowed
if there is a fuel limitation then only water should only be allowed to be sprayed. water was allowed to be sprayed at the pump gas drags.
the above gets you out of the power adder or not arguement completely
Old Jul 27, 2007 | 05:42 PM
  #70
great421's Avatar
Default I'm not buying the seat of the pants changing...
WW - You don't need to agree, but keep in mind, you haven't driven my car.
(Now, the following is completely non-scientific / unreliable info)
FYI -
Both my Pop and my Step-father are drag racers w/ 40+ years under each of their belts; I let them both drive the car with the Meth system OFF then the Meth system ON - they independantly said their "seat-of-the-pants" / 'Butt Dyno' measured about +25 HP. Again, NONE of this is in any way shape or form scientific (so again, feel free to completely dismiss it).
I haven't been to the track this year, as my 3rd 10 bolt is dying and I'm having a local (Greensboro NC) make me a 9 inch, or I'd go to Piedmount Dragway tomorrow and get before / after 60' and 660' info.
If there is a car in your area with Meth, drive it ON and OFF, see for yourself, it does indeed help.
Old Jul 27, 2007 | 06:24 PM
  #71
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Why can't I wear flipflops in some restaurants? Oh wait we having an important debate about meth.
The problem with meth is that folks treat it like 200 octane creator when it's more like 100-104 octane creator.
Old Jul 27, 2007 | 06:52 PM
  #72
Drewstein's Avatar
Boost to boost, by adding meth I will gain rwhp from the cooling properties alone. That is a power adder is it not?
BTW I still think it's a fuel. I also think it's a band-aid as well but that's a different thread lol.
Old Jul 27, 2007 | 07:20 PM
  #73
...I think the LSX shootout rules said something about it being prohibited in certain classes..
And that's fine. . . as long as they prohibit it as a fuel not a power adder.
Mike
Old Jul 27, 2007 | 07:22 PM
  #74
otherwhitemeat's Avatar
That was all I saying is it adds power, up and above fuel or racing fuel, and there in it self, it could by some need to be class regulated like a power adder.
Old Jul 31, 2007 | 03:09 PM
  #75
1320's Avatar
engineer mike, thats great information, I appreciate the effort, thanks.
gotta go, Ill be back later.
Old Jul 31, 2007 | 03:40 PM
  #76
ninetres's Avatar
Hey guys. I was thinking about adding a new part to my car on the intake inlet of the turbo. I figured it would lower my intake temps and increase power. Is this considered a power adder?
