re-tune critical after IC install on STS kit?
As far as the tune is concerned, with your IATs dropping, it can give you the chance to run more timing possibly and increase hp. A tune will likely give you the most out of the IC. Does synergy offer a retune option?
I would def, get a retune, because you can run 9-10 psi, and get another 40-60 hp.....
You would be crazy not to do it!
Maybe Im wrong, but you have abuilt motor, Heads, Cam, STS kit etc.... And your only putting down 450?
