STS M6 Owners - What gear are you running?
For an auto, 3.42 is generally considered the best gear because the turbo likes a load.
I know someone who is building a forged 383 and will run an STS at 12 lbs. of boost. What gear should he run with his M6?
Thanks.
Thanks.
i think it would really depend on what kind of racing he's gonna do. i mainly do highway rolls, so im gonna be moving to 2.75's pretty soon. but for track, the 3.42's sound good for the auto. i like lower gears, like a 3.08 or the 3.23. but i've never owned an auto fbody...... so i dont know much about the Autos
He is considering a 4.11. For a N/A auto, 3.73s are recommended. But for a turbo, 3.42s are recommended because the turbo likes having a load. I was wondering if the same holds true for M6, do they run better with a higher gear? My guess is that 1/4 mile runs are in his future, since he was considering such a low gear.
Thanks.
Thanks.
Thanks.
Thanks.
I run 3.70's. So far haven't really had any good exp. at the track. But, In the 1/8th im at the top of 3rd gear. Hopeing to get my car back this week and will be going to the track this weekend.
Originally Posted by enginjoe
I say no to 4.11s from experience with the STS kit. I have full boost later than I should and run out of gear well before the traps. I'm going back to 3.42s if I stay M6 after the motor rebuild.
The problem with the 4.10's on a turbo car is the lack of load through 1st in particular. The car is going to rev through the rpm's quicker, and you'd be lucky to see any boost in 1st.
I'm thinking about going auto too. A nice auto, nice stall, equals crazy launches!!
Another first hand experience with 4.10's with an STS. I installed the gears before I decided to go turbo and I ended up putting the 3.42's back in. WIth the 4.10's I ran through the gears so quick I barely even came to full boost and when I did it was for a millisecond or so.
3.42's are your best choice with an STS kit for sure.
Since I do all my own wrenching I am going to do a 3.73 install just to feel out the differences between the 3.42 and 3.73 to see if I can squeeze a better time with a little more accel. on the gear end.
Well i guess it settles it. I'll order the 3.42 ratio when i order the D60. I appreciate all of your opinions. now i have another question to post about how low can i go with the suspension with the STS setup.....I'll start a new post ....
Originally Posted by blackcars
Interesting...I have the GT67q turbo upgrade with the water meth and i'm running the precooler from TRTTurbo for added protection. So you're saying with the 4.11's the turbo will not spool enough? Or too soon? Glad i haven't put the rear on order yet... Right now the engine is a 383 with factory lt1 heads etc. But i'm putting together a forged 383 with AFR LT4 210 heads for some pep. I guess i should keep my head out of NA thinking and realise the turbo is a different animal. I read somewhere that the STS turbo can be setup to boost early rpm range or later rpm range. My thinking was getting the rpms up there for the boost and 4.11's would do that nicely or so i thought. I guess really sitting down and looking at it the 3.42's would make better sense. Why would you not stay M6? Are you breaking parts?
