Gen-TT Truck Systems
This week we have had some more development time on the Gen-TT GMC Truck systems, and have designed the fitment around the 2500 series and 3500 series HD AWD cars, so one product fits all. Props to the guys for spending the hours and getting the hard yards done
We have managed to lay the intercooler on a 15 degree angle which means we can still mount it above the level of the transmission crossmember, and front lip while still giving it sufficient airflow, all without modifying the body structure in any way
We have mounted the twin GTDW2833 turbochargers alongside the sump but with excellent rail clearance for the torsion bars and driveshaft of the 4WD variant. They are nice and stealth here, and have excellent ground clearance (above the level of the transmission crossmember yet again). Note there will be a complete Y pipe for the kit with the exhaust, the twin outlets are just a test piece
The engine bay looks as stock as it did before save for the intercooler discharge pipe which runs back up to the Drive By Wire throttle body, and still gives enough room to retain the stock fan assemblies
If you look at the Silverado from the front there is excellent ground clearance, and the promise of 100% torque and power gains on offer from the Gen-TT GMC Truck Intercooled Twin Turbo System
If we can make a nice easy 500rwhp through the 5.3 LS1 and auto at 8psi we will be really happy. The good news is that full boost and torque will be at less than 3000rpm making for a very fast Gen-TT Intercooled Twin Turbo ride
Im not telling you how to do your job, just sharing my experience.
As you can see all the pipework is high strength lightweight aluminium with rolled ends to ensure hoses never blow off. Our silicone is durable multi layer material with four levels of fabric for maximum strength. Notice the billet blow off valves?
Will get you guys some numbers in the next couple of days
i have a buddy with a 5.3 and he's getting his own twin set up custom...... wonder how that will turn out too
good luck tuna, should be bad ace
