408+ ci with FI, need suggestions
I'm looking for a cam that will be a max effort cam but still be able to idle (if thats possible). What are your opinions?
The issue is that I'll most likely need to go with a hydraulic cam because of the limited valvetrain available for the L92 heads.
Do I need to go solid roller?
I'm also looking for valve springs that will give me seat pressure in the 250-280 range because of the boost levels.
My last question is will the L76 intake be able to handle the 20-25psi boost levels? What is the max boost that a composite intake can handle?
Keith
EDIT: I forgot to mention the valve springs. TEA did the port work on my Dart heads gave me a set of 1.300" dual spring with a 160lb @ 1.800" seat pressure and 450lb @ 1.200" open pressure. They told me that is the most they would recommend for a hydraulic lifter. Any more and it would collaspe it. He was concerned about my lobe design and boost thinking it might cause valve float. 12psi at 7000rpm and nothing yet. I have more pulleys to play with.
