My OFI kit Dyno results!
Old Aug 2, 2007 | 09:34 PM
ddnspider's Avatar
Originally Posted by Got Me SOM
why do damn rich? lol damn trying to wash out your rings or what?
extremely impressive numbers but damn that's a lot of timing for a stock bottom end car.
11.9 is really rich?i think the meth cancels out the 22*
Old Aug 2, 2007 | 09:46 PM
Got Me SOM's Avatar
thought he said his afr was in the 10's..
Old Aug 2, 2007 | 09:50 PM
venom ws7's Avatar
Stock bottom end wow man AWESOME numbers.
And 22timing with 14.5psi.
Old Aug 2, 2007 | 09:54 PM
ddnspider's Avatar
were u talking about frost?i thought u meant the thread starter.my bad.
Old Aug 2, 2007 | 10:27 PM
6techniques's Avatar
nice numbers man...Do I see another Hwy.100 bully?
Old Aug 2, 2007 | 11:47 PM
BADDLS1SS's Avatar
Yeah ive been known to play "sleeper" on hwy 100 before haha.
Mine runs in the high 11's for AFR @ WOT typically due to where i have it set in the boost enrichment table (3 bar). but mine does go rich ( high 10's low 11's) during part throttle under boost due to a tuning issue i have not corrected yet.
Technically i could move to 20 PSI yet and 25* timing or so if i wanted to. It was doing 15 psi and 18 degrees with no methanol on straight 93 wth no knock. My AIT only shows a 15 degree increase over ambient w/o meth due to a decent A2A intercooler. It stays right at ambient or 5 degrees less when using the meth.
Its not a totally stock bottom end, i basically got rid of the TTY bolts and glass-like pistons.
I drive this thing around set on kill all the time and i pound the **** out of it quite a bit... it hasnt done anything stupid at all suprisingly, and drove it home in stop and go traffic with being 93 out and never got above 200.
Old Aug 4, 2007 | 03:51 AM
FastPacedGTO's Avatar
this car rocks. in person when it was low boost it was impressive.
I got in a 3-way run from a roll, and it really was like a Jet. It was him, I and a Mustang, and intitally I pulled out then you hear this jet-like sound and he goes flying past. Turbos on v8's are badass! This was when he just barely had it dialed in with low boost. I'm scared to see what it's like now that he doubled the boost.
Old Aug 4, 2007 | 06:24 PM
bhz28's Avatar
nice numbers!
Old Aug 6, 2007 | 01:49 PM
tt427ls1's Avatar
LS1TECH Sponsor
WOW...those are some great numbers. Glad to see you have it up and running. Shine her up for the photo shoot. What month mag will it be in?
Great job!!!
Old Aug 6, 2007 | 02:41 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Nice numbers, and the engine bay looks great on the car.
Old Aug 11, 2007 | 07:31 PM
DanZ28's Avatar
Very Nice!
What is the exhaust system on it, sounds good...
Old Aug 12, 2007 | 04:56 PM
  #32
BADDLS1SS's Avatar
Not sure what month yet i ended up DESTROYING the clutch at the track after the shoot. Come to find out the spec 3+ disc blew apart and i drove it home with no clutch since the shrapnel would not allow the clutch to disengage.
Coasted to a 12.017 @ 130.22
bogged the launch, 2.0 60' spun in 1st-2nd, hooked in 3rd and the clutch slipped BAD, (never seen over 10 psi boost till 4th) Got into 4th and the clutch bit and got up to 15 psi finally and i ran out of gear about 300 ft before the traps ( 4th taps the rev limiter @ 136) and when i was about to shift into 5th i realized the clutch would not allow me to do so, ended up caosting through the traps trying to pound it into 5th.
So time for a Spec super twin, trans freshen up and some diff gears. Stay posted for better, non supra like performance.
The exahust is an SLP 2OTL.
Old Aug 12, 2007 | 06:07 PM
  #33
DanZ28's Avatar
To bad about the clutch, looks like you were on your way to an easy low 10 sec run or better. What RPM do you make full boost at? What gear you running now and what's your rev limiter at? Sorry for the hundred questions, but I'm real close to making the plunge and ordering the OFI kit myself.
BTW, the 2OTL has always been one of favorite sounding exhausts out there...
Old Aug 12, 2007 | 07:37 PM
  #34
tt427ls1's Avatar
LS1TECH Sponsor
130 your cooking for a burnt out clutch. You think it feels better then the old setup?
Old Aug 13, 2007 | 09:56 AM
  #35
BADDLS1SS's Avatar
My rev limiter is @ 6800 currently and i run a 3.73 gear right now with a stock tire height 275/40/17 MT drag radial. ( which this thing litterally smokes the tires in 3rd from 65 to 100 when boost hits on the street)
Now that i got the part throttle tuning working better its not rich going into boost anymore like it was on the dyno. It makes 10 psi by 3200 now and 15 psi 3700 if it doesnt start spinning first. Where on the dyno it was rich going into boost and would slow the spool up and would hit about 4500 or so.
Got a spec stage 5 on the way, trans synchro kit and 3.42's and new drag radials ( i killed in 500 miles w/o one stationary burn out or hole shot lol)
Need to find a 2 step too yet.
I really want this to be a pull up and run right off the street 9.90 car before the end of the year.
Yes it feels WAY better than the 200 shot ever did on its best tune up. Its like the nitrous hit... ALL the time lol
Old Aug 13, 2007 | 10:04 AM
  #36
2000 Tran Zam's Avatar
those 3.42's will help a lot with spool too im thinking... maybe it can put enough load on your motor to bring full boost by mid 4k.
Old Sep 15, 2007 | 08:53 PM
  #37
BADDLS1SS's Avatar
Well i dynoed the car again today in 55 degree temps.
Only saw about 13 psi and got a tick lean at about 12.3
Nothing really changed engine wise since the first time.
693 HP 743 Torque Got any stumps that need pullin???
It was acting alittle ghey on the dyno, but if it got a full psi and the same 11.8 afr it does on the street i would say 720 and 750+ were in line.
I will post the graph later
Old Sep 15, 2007 | 10:02 PM
  #38
theblur98ss's Avatar
great numbers....get that thing to the track
Old Sep 16, 2007 | 01:19 AM
  #39
BADDLS1SS's Avatar
Track times coming this week!
Old Sep 16, 2007 | 02:29 AM
  #40
camarokid94's Avatar
unreal i need to rob a bank so i can get rid of the nitrous and get a turbo or procharger GRRR
