My OFI kit Dyno results!
As noted before the car was acting al ittle retarded on the dyno, and was breaking up a bit over 6K, it went lean (12.5) and started diving. It holds stead at 11.8ish on the street though.
It would have made like 720 and 750+ if it could have got enough load to hold 15 psi and if i would have richened it up on purpose for the dyno.
Joel, thats cool if u wanna use pics and #s etc... let me know if you need the orgional raws of any specific ones.
Yeah its not like this thing gets driven around on low boost and then turned up.... Its set on kill all the time, i pound the **** out of it every time the ket goes in the ignition and it doesnt do anything stupid. Maybe im just lucky? Not sure, i do know what im doing with the tune up on it... maybe that has alot to do with it... who knows.
The intercooler system works so well in this thing that it only rises 15* above ambient under a full 15 psi run on the dyno. And it stays at ambient or 10 * less with the methanol. I run 23* (could go more) total timing in boost regions and 30 degrees up to boost to help the turbo spool.
The engine acts the same w/o meth too on the same timing on 93 octane, its just a saftey net.
Its been my finding that a low CR is a crutch for inadequate intercooling and lessens the chance of knock due to not heating the charge as much during compression, but then you dont get the same kinda torque either you would with higher CR like mine.
I cant say anything bad about Joel at all!, hes helped me out with whatever i asked him to and its my fauly for being a little inpatient at first on the wait times... but in the end it payed off and ive got a 700 HP through a catback'ed daily driver that gets 23 mpg and is as docile as a cam only car and still has plenty of nuts under boost yet.
. In fact, I'm sure I will get the kit before the S91 shows up and I ordered them at the same time...Dan
This thing is nothing exotic thats the cool part... And ive got about close to 2000 miles on it now with the kit. and about 1500 on it as a sprayed motor.
