single turbo on a4s
Old May 20, 2003 | 11:21 PM
02BlueFirehawk's Avatar
Default single turbo on a4s
What kind of gains are people seeing with the ls1motorsports on an A4. Is their 7psi really safe for a stock internals engine? Could a boost controller be adapted to this system?
Thanks,
Rob
Old May 21, 2003 | 07:22 AM
SS00Blue's Avatar
Default Re: single turbo on a4s
Mines a M6, but I dyno'd 436/485 at 7lbs on a Mustang dyno with the LS1 intake and all stock longblock (except the upgraded 918 springs). It's typically agreed that one would see closer to 475/525 on a Dynojet.
Taking an extra 5% loss for an auto and adding 20rwhp for the LS6 manifold, you're looking at around 467/514 on a Dynojet. No small potatos.
I've only got around 300 miles on the kit, but it runs flawlessly. My motor had less than 8% leakdown on all cylinders, so it was in good shape to start.
I build my own Grainger BC, it works perfectly.
SC-
Old May 21, 2003 | 12:48 PM
Thanks for the reply. I'm putting down approx 319rwhp with 380rwtq now. My best was 11.85 @ 113.5 so with good air I can get close to 400rwtq. So I'm going to guess 469rwhp and 550-600 rwtq. That should be good for some low 11s high 10s.
Old May 22, 2003 | 06:37 PM
supersp0rt's Avatar
ill give you results on mine if i ever get it. i already dynoed 360rwtq last year on a 10/1 a/f ratio...so im expecting somewhere in the neighborhood of 550.
Old May 22, 2003 | 10:38 PM
fastls1inaz's Avatar
Just mt 2 cence.Isnt the comp ratio a little to high or should I say to close for comfort for a stock short block?Plus you would have to run good gas all the time.Correct?10.5:1 is a little high for a turbo motor,I know it's only producing 7-8#'s but detonation kills.My 89'tta can only run 14#' without detonating and its 9.2:1.Correct me if I'm wrong but thats just what i think.
Old May 24, 2003 | 12:56 PM
supersp0rt's Avatar
stock comp ratio is 10.1...and im not expecting my motor to last forever. i will have a very accurate dyno tune and be running roughly a 11.5/1 a/f ratio at al times. i think it will last for quite some time (my car is not a daily driver)but hopefully ill have the funds to rebuild before it does, say a year down the road.
Old May 24, 2003 | 03:14 PM
Blkknight's Avatar
Boost controller isn't an issue. I'll probably be running the Greddy E-01 controller. Mine wil be put together before yours so if you like you could just stop by Jasons when its complete and take a look.
Old May 28, 2003 | 02:01 AM
Thanks dude. Keep me informed on when you get yours done.
