how much boost stock ls1
Old Aug 8, 2007 | 02:22 AM
baldwintpenguin's Avatar
Default how much boost stock ls1
I cant find anything through search....how much boost can I SAFELY run on a 100% stock LS1. Im considering going with the remote location sts system. The car will be daily driven. Aslo how much boost can the ls1 block handle? At what point will the block just crack? I know I'd need to go with different heads and upgrade alot, but how much boost can the actual block handle? Thanks for any input or even pointing me in the right directions.
Old Aug 8, 2007 | 02:30 AM
tx3's Avatar
tx3
safe boost would be under 10lbs. id personally recommend for a VERY SAFE situation.. 5-6lbs. but for still a safe yet fun ride. 8lbs will do the job.
Old Aug 8, 2007 | 02:46 AM
daniel6718's Avatar
limit is more in the power you make i think...try not to get over 600 rw
Old Aug 8, 2007 | 02:49 AM
bboyferal's Avatar
Your block will not suffer any damage under 1k rwhp most likely.
You should be worrying about the stock pistons which may begin to crumble for most at power levels of 500 rwhp and up.
This is assuming a competent install and spot on tune. In terms of boost that is about 8-10 psi on an otherwise bone stock LS1.
Old Aug 8, 2007 | 04:17 AM
EPP's Avatar
EPP
I agree, I'd go for 8 psi on your stock pistons, and the block itself can handle somewhere around 1000 rwhp. Bob
Old Aug 8, 2007 | 09:08 AM
BlackScreaminMachine's Avatar
Internet Mechanic
THe way its been described to me is a ratio, 3 hp per 1 cubic inch ratio, Once you go beyond that, **** starts to break. Which is around the 1000 hp mark.
Old Aug 9, 2007 | 05:13 AM
So lets pretend that 1lb of boost = 25hp. Your telling me that I could run 25lbs of boost and my block would be ok? obviously alot of other things would not be ok but my aluminum block isnt gonna blow to piecies? Other things take into consideration of being able to run 25lbs of boost I do understand that though.
Old Aug 9, 2007 | 06:15 AM
daniel6718's Avatar
aluminum blocks are pretty strong...think they do have iron sleeves..
Old Aug 9, 2007 | 08:59 AM
Internet Mechanic
Your math is flawed, it doesnt make sense, there is no set hp per 1PSI of boost # There are alot of factors that work into an output of a motor. Speaking purely about the motor, the blocks tend to have issues at the 1000 hp mark, not to mention the rods and pistons may fail far before that #.
Old Aug 10, 2007 | 12:43 AM
I coulda swore I made it very clear in this post but apparently not. Yes I know the math is flawed. I was using it purely as an example.
But thanks for the info everyone, I've decieded to build my LS1 for as much boost as possible before upgrading to more cubic inches if i'm not satisfied with the output.
Old Aug 10, 2007 | 09:02 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
10 psi or less on a great solid tune.
Old Aug 10, 2007 | 09:13 AM
MrDude_1's Avatar
your pistons are the most fragile thing in the shortblock.
then theres the rods.
your crank and block can take over 1000hp without issue... over 1000, things might start to wiggle a bit, but noone yet has broken an LS1 block from too much power... they have however started to see stuff move around a bit over the 1k mark.
this isnt a ford block, we actually have metal holding the two halves of the block together.. LOL
Old Aug 10, 2007 | 12:31 PM
bboyferal's Avatar
Very true, but I have yet to hear about a stock rod failure.
Old Aug 10, 2007 | 12:39 PM
MrDude_1's Avatar
lookup the words "spun" and "bearing"
Old Aug 10, 2007 | 01:12 PM
Internet Mechanic
If you want max power, do it all at once, if you want to run until you blow it, you could **** the block which means more money.
Its on or around 8 psi.
Old Aug 10, 2007 | 05:09 PM
do you guys know of anyone that sells a kit for practically all the fordged internals i'd need to run high boost and not blow the hell outta my engine? Or at least a good trustworthy company that sells them?
Old Aug 12, 2007 | 06:08 PM
djsanchez2's Avatar
Lunati & Eagle for rotating assemblies. Plus alot of other companies that make parts of the rotating assembly.
SLP, Extreme HP, Scoggin Dickey, MTI, Texas Speed, W2W, and Thunder Racing for forged short blocks in multiple displacements.
Check the sponsors, there are alot of GOOD deals. I'm thinking of getting a forged 383 from SDparts or Extreme
Old Aug 13, 2007 | 10:10 PM
datsbad's Avatar
I have been pushing 12-13 lbs with my turbo . so far so good. !!!
Old Aug 15, 2007 | 11:55 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Old Aug 16, 2007 | 12:09 AM
bboyferal's Avatar
Not that often either...
Mine were fine after 10 psi on the stock longblock.
More often, at least in this forum and my limited experience, I hear about pistons taking a dump... Very often.
Of course, that is definitely a danger too.
