Ok Turbo Cam Masters!!
Here is the compressor map:
http://www.turbobygarrett.com/turbob...pmap_large.gif
Consumption for a 364 @ a PR of 3.0 (3 bar) @ 7500 rpm is ~130-135 lb/min, putting it right on the ragged edge of that compressor map
Backpressure will probably be pretty brutal up there due to the smallish turbine...which I think will allow the slightly later IVC.
Fireball,
You kept the same stroke but increased bore right? What is your target boost level with the new setup and where does it shake out on the compressor map and consumption chart for your motor? I think that cam looks pretty good but you might peak a little higher with the 48ivc versus 46 provided the turbo is still in its efficiency range and backpressure not too high.
I am starting with a 234/234 598/598 116+4
the engine is a 403 CID with AFR 225 heads
turbos will either be the APS kit or twin 66mm
Peter
You are right on the bleeding edge of the compressor map hehe
That combo is going to be nuts man you must be excited
30 psi + 9:1 compression should be pretty nuts....can you say goodbye headgaskets
232/232 116+4
Any opinions?
Kurt Urban made this point to me a few years ago, that 15psi will double the engine horsepower. So if I make 450rwhp NA like say LastLS1, at 15 psi I am making like 900 hp. Shows the value of cubes and running enough turbo. But say you make 375rwhp like me on motor (just a guess, could be lower). At 15psi I am a 750rwhp car.
Seems to me that going up or down a little on cam won't make much of a difference, it's when folks run way too much or way too little cam that you start to reduce the effectiveness of the engine itself.
I'm sure someone better versed in turbos can make the point that its not that simple, and that you want to not go too crazy with turbo cam choices, but I have also heard 2-3 reputable tuners say that is not true, that you run race car cams in race cars regardless of whether they are turbo or not.
ABDC - After bottom dead center
ATDC - After top dead center
EVO - Exhaust Valve open
BTDC - Before top dead center
Web, a bigger cam with a blower setup will be worth 20-40hp over a stock cam for sure. Turbo folks however look at the duration and try to curtail the amount of duration if they think they will run out of turbo. Turbo folks are much more focused on efficiency of the system.
These 4 numbers dictate alot, overlap, where the motor will make peak power, etc...
My first post in this thread gave my initial thoughts on the matter...
THe only valve event I really have any direct testing of was the IVC. THe overlap events (IVO and EVC) were based on what I ascertained from this thread as a starting guess.
EVO was based on typical larger cam numbers (though I don't think its a very sensitive number)
Can't wait to see it up and running!
