STS Help...
Old Aug 16, 2007 | 05:26 PM
00TurboTA's Avatar
Default STS Help...
Ok I have a T-60 STS, and I have had it for a few months now and I am gettin sick of the clearence issues, I haven't hit anything but I am not happy that the turbo hangs so damn low, I have hear of ppl either removing or hittin the heat sheild of the gas tank to tuck the turbo a few inches into the back of the car...and I am also gonna tuck the intercooler piping and basically any help with clearence issues on sts cars...thanks
Old Aug 16, 2007 | 05:52 PM
98camarossturbo's Avatar
i've had the sts turbo for 2 yrs now and never had any clearence issues with the back half of the car where the turbo is. the front is a different story i've bottomed out a few times with the pipe goin to the intake. my understanding is that with a intercooler it would correct this problem cause it's piped a lil different. plan on gettin one down the road and i hope it helps.
Old Aug 16, 2007 | 06:11 PM
00TurboTA's Avatar
With the intercooler the piping is run different but my charge pipe still hits if road is rough or upon really hard stops...fbod front end dive...but I am gonna try and re rout it soon, but I am sure that someone has tucked it...
Old Aug 16, 2007 | 08:08 PM
front end dive describes it perfectly. it definitly can be tucked up tighter with some custom pieces. go to exotic performance plus they did a sts setup for someone and modified the piece ur talkin about. they also have plenty of pics.
Old Aug 16, 2007 | 08:15 PM
trtturbo's Avatar
If you make a slight bend in the pipe that goes under the K member, it will be on an upward slope, so the lowest part will be right under the K member.
As far as the turbo, you need to clock the housings right and you will have good clearance.
Old Aug 16, 2007 | 11:26 PM
ZL1Killa's Avatar
that and if you see what they did at www.exoticperformanceplus.com on scott hewitts SS where they made a bracket to pull it up a little more... there ya go
Old Aug 17, 2007 | 01:51 AM
HossinatorSS's Avatar
yeah,no probs with the turbo, a couple of snags on the back piping as it goes from the middle to the side of the car. LOTS of probs with the front but that was with pro-kit which is gone now
Old Aug 17, 2007 | 01:54 AM
Cchris1109's Avatar
hey dude, if you wanna see my setup on how i did the STS it sits really high up
the exhaust shop can fab up the brackets and how i had my setup for like 100 bucks
let me know, ill PM you my number again
Old Aug 17, 2007 | 02:03 AM
2000TurboVert's Avatar
Yeah It does hang alittle low in my opinion... There are many ways to fix that problem, some guys are even using exhaust straps!(Dont know)
Old Aug 17, 2007 | 04:18 AM
RooRnZ28's Avatar
i havent seen a kit lower than mine, and i dont have any problems. its all in the way you drive...
my lowest point:
Old Aug 17, 2007 | 02:36 PM
quik01ss's Avatar
Default ...
my car is lowered with springs and I have a fmic no problems in front but the only thing I didn't like about the sts kit was the piece that loops over the diff. so I got rid of that and made it go under the diff. my turbo sits real nice off the ground and I made a piece when I was puttin the kit on to sit it higher......
Old Aug 18, 2007 | 12:05 AM
JAvenger007's Avatar
Wow that is low.
Old Aug 18, 2007 | 02:27 AM
Thats about normal for the pipe that runs along the frame in a STS kit!
Old Aug 21, 2007 | 05:47 PM
Alt's Avatar
Alt
Being that my car will be bagged in the near future how well could the rear turbo be tucked up since clearance could be an extreme issue if I lose pressure and drop my rear.
