My APS TT Install Thread
Old Aug 30, 2007 | 02:47 PM
  #41
n2ojunkie's Avatar
Looks good. Sorry I didnt make it or call last night, I finaly had a chance to make it to stanton last night. They didnt get any rain. It was a big disapointment thou. I'll give you a call in a little bit.
Old Aug 30, 2007 | 03:40 PM
  #42
Hugger Z's Avatar
Originally Posted by KWIKKAR
Dont forget that you need to drop the oil pan and tap it out before you put the K member in. Lookin good. Got my heads and pan off last night.
Oh I didn't forget. Been looking all over town for that freaking Loctite 567. Ended up getting 565 because it is the only thread sealant I could find without having to order it on-line. Planning to drop and tap the pan tonight and put a new oilpan gasket on as my old one was apparently seeping quite a bit at the front.
Old Aug 30, 2007 | 03:42 PM
  #43
Hugger Z's Avatar
No problem. Heading out to the garage shortly and will be there the rest of the night (except for dinner).
Old Aug 30, 2007 | 04:01 PM
  #44
WS6 John's Avatar
Are you using the KM003 BMR k-member?
Old Aug 30, 2007 | 09:53 PM
  #45
Reject's Avatar
i like this kit!! maybe i can step up to one of these and finally get blown!
Old Aug 31, 2007 | 08:06 AM
  #46
Hugger Z's Avatar
Yes I am. Ordered that right after I got my APS deposit confirmed. Been sitting in the garage waiting to go in the car. Should finally be bolted in this weekend.
Old Aug 31, 2007 | 08:07 AM
  #47
Hugger Z's Avatar
Made some good progress last night. Many thanks to James (n20junkie on LS1tech) who came down and assisted me. We dropped the oilpan and drilled and tapped the oil feed and drains. We also dropped the fuel tank so I can install my new pump. Prior to his arrival I re-assembled the motor mounts with the urethane inserts. They look nice now that I painted them! My new plug wires and plugs also arrived via UPS today. Woohoo! It's coming together! Should see lots of progress this weekend as I have nothing planned except for working on the car. Hoping to have it as close to complete as I can by Monday.
Attached Thumbnails My APS TT Install Thread-eng-mts_30aug07.jpg   My APS TT Install Thread-oilpan1_30aug07.jpg   My APS TT Install Thread-oilpan2_30aug07.jpg   My APS TT Install Thread-oilpan3_30aug07.jpg   My APS TT Install Thread-fueltank1_30aug07.jpg
Old Aug 31, 2007 | 08:30 AM
  #48
TNTramair's Avatar
lookin good. so...so far the only small issue you've run into was the AIR pump correct??
you didnt get to the cutting portion as of yet, right?
Old Aug 31, 2007 | 09:09 AM
  #49
Hugger Z's Avatar
Yeah the AIR pump was the only issue I have run into so far. Already made some of the cuts for the intercooler. Made the bottom lip trim and the large top edge cut and bend. Needed a smaller grinder for the 3" sections that get bent up (but ran into compressor issues). Once I borrow another compressor I should be able to finish that up. And a buddy is taking my bumper beam to trim with a plasma cutter for the clearancing that happens there. I have it all marked and ready to trim.
Old Aug 31, 2007 | 10:34 AM
  #50
mterveen's Avatar
Default k-member
did you get the kmr003 or the kmr001? i thought the kit came with its own motor mounts?
Old Aug 31, 2007 | 11:27 AM
  #51
Hugger Z's Avatar
I ordered the KM003. The kit comes with urethane inserts that go into your stock motor mount clamshell. You still need to get from the clamshell to the k-member. I believe APS recommended the KM003 in that long thread with the initial info. Somewhere in that 95+pages it is mentioned.
http://www.bmrfabrication.com/K-Members/km003.jpg
Old Aug 31, 2007 | 03:12 PM
  #52
mterveen's Avatar
Default k member
you're right. i stupidly thought since it came with its own motor mounts i would get the kmember without the mounts. duh...... called bmr and reordered. duh
Old Aug 31, 2007 | 04:13 PM
  #53
n2ojunkie's Avatar
Hey Todd I wont be able to make it tonight my cousin jus showed from WV. I didnt know she was comeing. I'll make it down tomarrow night and I should have my car. Have fun, lol
Old Sep 2, 2007 | 11:00 PM
  #54
Hugger Z's Avatar
Default Updates from Friday 31Aug07
Today the UPS man was VERY good to me!!!! The wheels are here!!!! Unfortunately one of the rear wheels has a gouge in it so they are drop shipping me another one. But 3 out of the 4 looks SWEET!!!! This is gonna be badass!!! And there is a preview of the brakes that will end up on the car later on. They will of course be painted Orange! But I think I still need spacers to clear these monsters. That is a mock-up F-body knuckle I have those mounted on for now to check clearances.
Also started routing the Racetronix hotwire kit tonight. It doesn't have any directions so just looking for the safest, most logical routing. Think I have it. Will get more pics tomorrow.
Attached Thumbnails My APS TT Install Thread-wheels1_31aug07.jpg   My APS TT Install Thread-wheels2_31aug07.jpg   My APS TT Install Thread-damaged-rim_31aug07.jpg   My APS TT Install Thread-brakes-preview_31aug07.jpg
Old Sep 3, 2007 | 07:41 AM
  #55
Orange Krush's Avatar
Cool
Subscribing!
Old Sep 3, 2007 | 08:34 AM
  #56
Hugger Z's Avatar
Default Updates for Saturday 01Sep07
Got the tires mounted to the 3 good wheels this morning. And I gotta say they look AWESOME!!! I am so excited to get the car back on the ground with these on it. The replacement wheel should be in Tues or Wed and I will get the 4th tire put on then. Many thanks to Ryan at Belle Tire for the tires/mounting/balancing. It was a better deal than getting them from the wheel/tire source I got the wheels from.
Next item of the day was finishing the routing of the Racetronix hotwire kit for my fuel pump. I think I found a pretty good routing and well hidden behind the factory heat shielding. Not bad if I do say so myself. Almost looks like it was meant to be there.
Ran the line for the turbo coolant from the engine block on the pass side.
Finished trimming the crossmember for the intercooler installation. Added the rubber stripping and installed the intercooler. Bolting those IC brackets on was a pain in the rear!
Also snapped some shots of my hoodlatch cable that is routed under the fender so it will not be in the engine bay anymore. It will be between the fender and plastic fenderliner.
Attached Thumbnails My APS TT Install Thread-wheels1_01sep07.jpg   My APS TT Install Thread-wheels2_01sep07.jpg   My APS TT Install Thread-wheels3_01sep07.jpg   My APS TT Install Thread-hotwire1_01sep07.jpg   My APS TT Install Thread-hotwire2_01sep07.jpg
My APS TT Install Thread-hotwire3_01sep07.jpg   My APS TT Install Thread-hotwire4_01sep07.jpg   My APS TT Install Thread-hotwire5_01sep07.jpg   My APS TT Install Thread-hotwire6_01sep07.jpg   My APS TT Install Thread-hotwire7_01sep07.jpg
Old Sep 3, 2007 | 08:37 AM
  #57
Hugger Z's Avatar
Default Updates from Saturday 01Sep07
More pics from Saturday....
Attached Thumbnails My APS TT Install Thread-hotwire7a_01sep07.jpg   My APS TT Install Thread-hotwire8_01sep07.jpg   My APS TT Install Thread-hotwire9_01sep07.jpg   My APS TT Install Thread-hotwire10_01sep07.jpg   My APS TT Install Thread-hotwire11_01sep07.jpg
My APS TT Install Thread-hotwire12_01sep07.jpg   My APS TT Install Thread-hotwire13_01sep07.jpg   My APS TT Install Thread-hotwire14_01sep07.jpg   My APS TT Install Thread-turbo-coolant-line_01sep07.jpg   My APS TT Install Thread-intercooler-clearance1_01sep07.jpg
Old Sep 3, 2007 | 08:39 AM
  #58
Hugger Z's Avatar
And yet more from Saturday!
Attached Thumbnails My APS TT Install Thread-intercooler-rubber-strip_01sep07.jpg   My APS TT Install Thread-intercooler_01sep07.jpg
Old Sep 3, 2007 | 08:42 AM
  #59
Hugger Z's Avatar
Default Updates from Sunday 02Sep07
Today was another busy day!! Alex dropped off my trimmed bumper. Painted the cut metal sections and set it aside.
Reinstalled the oilpan.
Installed the LH side coolant line. Needed a 17mm allen key to get that plug out of the block! It's huge!
Installed the battery tray, and coolant reservoir in the car. Subassembled the air deflector and washer bottle. This washer bottle looks pimp!
Valve spring & pushrod swap was next. Installed LS6 valve springs and stock length TSP pushrods. Big thanks to my buddy Tony for his assistance there.
And the final task for tonight was to hang the turbos on the car!!!!! Yeah baby!! It's looking good!!!!!!
Attached Thumbnails My APS TT Install Thread-trimmed-bumper_02sep07.jpg   My APS TT Install Thread-oilpan-install_02sep07.jpg   My APS TT Install Thread-turbo-coolant-line_02sep07.jpg   My APS TT Install Thread-battery-tray_02sep07.jpg   My APS TT Install Thread-radiator-overflow_02sep07.jpg
My APS TT Install Thread-air-deflector_02sep07.jpg   My APS TT Install Thread-washer-bottle1_02sep07.jpg   My APS TT Install Thread-washer-bottle2_02sep07.jpg   My APS TT Install Thread-valve-springs1_02sep07.jpg   My APS TT Install Thread-valve-springs2_02sep07.jpg
Old Sep 3, 2007 | 08:44 AM
  #60
Hugger Z's Avatar
More pics from Sunday.
Attached Thumbnails My APS TT Install Thread-valve-springs3_02sep07.jpg   My APS TT Install Thread-valve-springs4_02sep07.jpg   My APS TT Install Thread-turbos1_02sep07.jpg   My APS TT Install Thread-turbos2_02sep07.jpg   My APS TT Install Thread-turbos3_02sep07.jpg
