Sts
Old Aug 23, 2007 | 09:18 PM
BigJls1's Avatar
wont the cat back being larger pipe hurt preformance. I thought I read a few guys going to 2.5 pipe (vrs 3.0 ) and picking up alot of down low power without any loss in upper hp. rear mounts need the smallest space ( the pipe and cat) to fill to spool and work best. my .02
Old Aug 23, 2007 | 09:27 PM
NYSS Guy's Avatar
There are 2 main things you need to do to keep your stock motor together:
1) Get a really good tune. Get some kind of scanning tools if possible so you can keep an eye on things.
2) Don't get greedy with the power. I drove my car for over a year at 8 psi (475 rwhp), and the stock motor didn't skip a beat.
Old Aug 23, 2007 | 09:34 PM
jeremy02's Avatar
I'm only going with the base 5 PSI, and 2000TurboVert is suppossed to be sending me a tuned computer, tuned by PCMforless.com. Will that suffice?
Old Aug 23, 2007 | 09:41 PM
JAvenger007's Avatar
I would recommend opening up your downpipe to 4" right off the outlet and getting something like a 12" bullet (magnaflow or dynomax) and chop off the remainder of the STS exhaust pipe in the kit. Put the bullet in there and weld a tip on the end.
Old Aug 23, 2007 | 09:49 PM
zapp168's Avatar
I own my shop.....I make my competion mad all the time......I know where your at....
Old Aug 23, 2007 | 10:24 PM
koolaid_kid's Avatar
I agree. My computer/scanner lives in the front seat. Wouldn't go anywhere without it, especially Saturday nights.
And I only run 7 pounds of boost, which is fine with me. If I had a forged bottom end, things would be different. Mainly a different rear end after I broke the stock one and a different trans after I broke the stock one.
Old Aug 24, 2007 | 03:33 PM
NYSS Guy's Avatar
I will be okay, but not ideal. Especially with a turbo car, since the boost is based on load (not rpm), it's not as accurate to just use a mail order tune. I had a mail order tune when I first started, and the car ran pretty lean. I didn't break anything, but I did end up getting it re-tuned again.
Old Aug 24, 2007 | 03:46 PM
RooRnZ28's Avatar
yes, get a dyno tune, not that mail order stuff. i had a mail order tune for my CAM only, and the car ran like total ****! the tune was only good for the idle
Old Aug 24, 2007 | 05:31 PM
A turbo will never get a perfect mail order tune. I got one to get me in the ballpark, but I have been refining it myself since then. If you don't have the equipment to do it yourself, get a custom tune as suggested above.
Old Aug 24, 2007 | 05:43 PM
Alt's Avatar
Alt
I would say that a mail order tune would be great for him to drive to the tuner with.
Old Aug 24, 2007 | 06:47 PM
If he is going to get a dyno tune, don't bother with a mail order tune. As long as you don't change the injectors until you get to the tuner, the car will be driveable. Voice of experience.
Just drive to the tuner, put in the injectors, and get on the dyno.
Old Aug 24, 2007 | 07:07 PM
  #32
2000TurboVert's Avatar
Thats all pretty good advice... It just depends on whether or not he wants to splurge for the dyno tune!!!!!
by my recommendation, hes going to make an appointment @ vengeance racing in atlanta... THey are THE BEST.. HANDS DOWN... Their customer service is TopNotch and if he does get the tune, they are Hands Down the best tuning place in the south!!
Old Aug 24, 2007 | 07:17 PM
  #33
RooRnZ28's Avatar
myself, i wouldnt drive it at all until it gets tuned. get it towed. anything bad happens while driving to the tuner, and your project just got more expensive. others may have had good luck, but thats my opinion. after all the **** i've been through with this kit, i wouln't take any chances.
Old Aug 24, 2007 | 07:52 PM
  #34
As long as you do not go into boost, your engine is the same as it was prior to the install. Think about it a while, and you will understand what I am saying. Hope this helps.
Old Aug 24, 2007 | 08:58 PM
  #35
NYSS Guy's Avatar
koolaid is right...just don't hit boost. Besides, from my experience, the mail order tune wasn't that much cheaper than a full dyno tune. After spending money on a mail order tune, then a dyno tune, I finally spent the dough on a laptop, wideband, and HP Tuners to do it myself. Everyone is different, but if I had known then...I would have just bought all the equipment to do it myself from the beginning.
Old Aug 24, 2007 | 09:50 PM
  #36
jeremy02's Avatar
Well, I really hopehope the mail order tune will do, cause I just don't have the money for a dyno tune.
Old Aug 24, 2007 | 09:58 PM
  #37
The mail order tune will be FINE! until he can afford to get the dyno tune!
Hes running an intercooler 5.5psi! He will be fine! Brian @ PCMforless.com is the best out there interms of mail order!
Old Aug 24, 2007 | 10:31 PM
  #38
99Z28LS1's Avatar
i think it's an easy kit to make power with....... 5.5-6 psi with cam and matching fuel + intercooler and made 503/512 with stock clutch and LT and ORY
if you have factory manifolds then you are ahead of me (for the time being..... i have ported and coated sotckers on the way with a coated y pipe) and i have a custom I pipe
you will ove it man, a little laggy, but you'll still stomp some ***
Old Aug 24, 2007 | 11:44 PM
  #39
jeremy02's Avatar
Wow...that's the first bad thign I've heard in terms of lag.
Glad to hear I'll be ok with the mail order tune.
Old Aug 25, 2007 | 08:38 AM
  #40
Alt's Avatar
Alt
Couldn't you not put in a wastegate spring and make sure that you don't make any boost?
