Pulley change (ATI)
Old 05-26-2003, 06:29 PM
White SS's Avatar
Default Pulley change (ATI)
What is the best way to change pulleys?
Old 05-27-2003, 05:13 PM
White SS's Avatar
Default Re: Pulley change (ATI)
ttt
Old 05-28-2003, 08:52 AM
Moderator
Black LS1 T/A's Avatar
I take the SC off the car.
Using an old belt looped around the pulley and doubled back, I tap firmly on a socket wrench to loosen the bolt. Unscrew the bolt.
I spent less than $20 bucks for a puller like this:
Takes about about a minute or two to screw the pulley off.
To put the different pulley on, I heat it in the oven on 350 degrees for about 5 minutes. With the shaft key in it's slot, I pick up the pulley with pliers and drop it on the shaft. One tap of the hammer and it is in place.
I put Red Loctite on the bolt threads and tighten it back down. Using an old belt (again) looped around the pulley and doubled back, I tap on the socket wrench to tighten the bolt some more, and I'm done!
Old 05-31-2003, 11:18 PM
2001SS#3013's Avatar
Sorry for such a stupid question but what is a socket wrench. Do you have a picture?
Old 06-01-2003, 05:36 AM
Moderator
http://www.nascar.com/2003/kyn/tech/.../laser_socket/
or here's another pic:
from The American HeritageŽ Dictionary of the English Language: Fourth Edition.
I hope you don't work on cars.
Are you playin' wi' me?
Old 06-01-2003, 07:12 AM
AzzHauler's Avatar
Location: Richmond, VA Where fast cars, well......are hard to come by.
He probably calls it a rachet. I hope.
Quick Reply: Pulley change (ATI)
