800HP Project
Old Mar 16, 2008 | 08:43 PM
  #41
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by Slowhawk
I also run a shift kit wit hthe built tranny.Was hard as hell in the biggining.I actually lowered the line pressure which helped alot.Shifts tight at part throttle and chirps all gears at WOT. The 4l80 tranny program leaves alot to be disired.Took me almost a month to get it where I like it.
Do you have that annoying decel unlock with your TC? It appears to afflict several of us with 4l80 segment swaps in trucks. If you just barely get off the throttle, it unlocks, then relocks when throttle is applied. There is a thread about this on the HPT forums, and it doesn't seem to be affected by any tables we have access to.
Old Mar 16, 2008 | 09:14 PM
  #42
Bismarck's Avatar
Yes I have this problem and indeed its very annoying. Has anyone figured out a solution?
Old Mar 17, 2008 | 08:06 PM
  #43
gametech's Avatar
I just checked the relevant threads on HPT's forum. So far no luck.
Old Mar 18, 2008 | 11:02 AM
  #44
BadCompany VP WS6's Avatar
Can we see pics of the truck??
Other "race" escalade's are inquiring to know.
Old Mar 18, 2008 | 11:04 AM
  #45
Bismarck's Avatar
yes will take a few today !
Old Mar 29, 2008 | 11:36 PM
  #46
RFFG's Avatar
Damn, awesome setup...
Old Mar 30, 2008 | 12:13 AM
  #47
Bismarck's Avatar
Pics tomorrow, I promise
Old Mar 30, 2008 | 11:06 AM
  #48
venom ws7's Avatar
Damn awesome project the car will be the ultimate sleeper.
PICS PICS PICS VIDS VIDS VIDS
Old Mar 30, 2008 | 12:27 PM
  #49
DanZ28's Avatar
Looks to be a very nice setup.
BTW, for dyno testing I know of one shop that got a spare transfercase and modded it to be a two wheel drive for the denali he built. Allowed easy tuning on the dyno, then swap it back afterwards to the AWD.
If I was building a high power street setup, I would go a simialr route with a twin turbo. AWD rocks on the street with power.
Dan
Old Mar 30, 2008 | 08:20 PM
  #50
Bismarck's Avatar
I looked into the twin turbo route. I too may consdier it. Now that its dialed in things are working pretty good and the twin screw type is a nice setup for daily driving IMO. Both are nice....
Old Mar 30, 2008 | 11:21 PM
  #51
DanZ28's Avatar
No doubt the the screw works awesome, again very nice .
Old Mar 30, 2008 | 11:42 PM
  #52
Bismarck's Avatar
well, I had promised photos, but did not get a chance. Wife was already pissed off that I worked n the car the whole day.
Moving the battery to the left so I can shorten what I call the swage pipe... waiting for the cold air box from S&B to come in. What a pain, have not worked on cars in a while.. whole bynch of trips to hardware store and autporats just getting clamps, etc.
Finally got to a point that its manageable, but still probably another days worth of work is needed.
Old Apr 1, 2008 | 01:45 AM
  #53
Bismarck's Avatar
Well some more work still. Man moving the battery and washer fluid reservior form right side to left proved to be way complicated. Still not finished with it. Hopefully tomorrow.
Still have to install the Meth/water injection.
Old Apr 1, 2008 | 01:54 AM
  #54
Websy21's Avatar
Where is the pics bro!
Old Apr 13, 2008 | 02:14 AM
  #55
Bismarck's Avatar
Default Pics Finally
Guys, here are som epics. Sorry the car was super dirty... Detailing tomorrow. Its not done yet, Methanol/Water injection is left and also some cleaning up id dtill left.
Finally got rid of the long intake... S&B box had to be heavily modified to fit, but now fits nicely. I have another one that I will exchange... will be able to do it better 2nd time around. Added the Catch CAN.
Apologize for the filth. Had just added transmission fluid...
BAttery and stuff moved to the left side....
S&B is erally a nice kit...
The freaking pulley flew off once. Lock tight was not enough, had it spot welded.
Sorry again about the mess, better pics in a couple of days.....
Running the Whipple at 13psi with 13 degrees of timing. Will go down to 7. Little bit at a time.
I ordered Black ones, but got Red, did not want to mess with them.
I was contemplating going to a 12 rib pulley but decided to settle on 10
AFR 225 with 72cc Chambers. 10cc over stock with 8.5:1 ceramic coated pistons. Leaves room to run up to 15 psi no problem. Will be adding a meth injection from Snow perfromance for full throttle and very hot days
This took a long time. The washer fulid reservoir and other stuff moved.
Here you see the pan of the 4L80. Nothing much more you could see.
The drive shafts for both front and rear are much beefier than stock and U joints are also very thick.
Installed two B&M tranny coolers. The damn thermo switch on them works real crappy, bypassed it. Have to figure something out here. any suggestions? Can I get a reading from the PCM and and trigger a relay with it or just leave it on the whole time?
Freaking 4L80 still gets hot. I am thinking of getting one of Oil Pans with tubes in them to flow air. anyone haveexperience with them?
Ron Davis made the intercooler for me. I had it made as large as possible. thinking about painting it black. Wondering if it will degrade its prformance... any suggestions on a good paint that conducts heat well?
Here you can see where the wheels have been widened. Did this myself, we do it for bikes all the time.
Old Apr 13, 2008 | 02:33 AM
  #56
Websy21's Avatar
So this is what has been keeping you from the wify, LOL Looks very nice, now take it for a test run video
Old Apr 13, 2008 | 12:01 PM
  #57
DanaliHD's Avatar
so much for the whipple 3.3L NOT fitting our trucks. damn that is awesome. Make me one of those intakes!!!! i NEED one for my kenne bell
Old Apr 13, 2008 | 12:04 PM
  #58
Bismarck's Avatar
Yes its a catch can... was badly needed.
Old Apr 13, 2008 | 12:22 PM
  #59
DanaliHD's Avatar
did i mention i hate you? wait, that's right, i did.
Old Apr 13, 2008 | 12:25 PM
  #60
Bismarck's Avatar
No problem man, I hate myself too :-)
