max boost on bone stock motor???
Old Sep 4, 2007 | 07:20 PM
mycar2fast's Avatar
Default max boost on bone stock motor???
hey all i just got my sts kit with the gt-67 upgrade, i have 36.5 injectors stock fuel pump, and will soon have a bar and plate fmic, was wondering whats the most boost i can throw at my motor with these mods safeley? and what will i have to do in order to make 10lbs of boost....
thanks in advance!
Blake
Old Sep 4, 2007 | 07:26 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
15 psi
Old Sep 4, 2007 | 07:28 PM
vaticano's Avatar
depends on yout altitude. here colorado ive heard that a 10:1 motor can go 15#'s. but otherwise a stock ls1 can handle about 8#'s. if you want 10#'s get meth injection or switch over using e-85/ ethanol
Old Sep 4, 2007 | 07:29 PM
ChevyChad's Avatar
maybe 30# if you add meth
Old Sep 4, 2007 | 07:32 PM
Websy21's Avatar
Originally Posted by ChevyChad
15 psi
I bet if you even go back a couple pages it would be there because it gets asked atleast once a week!
Old Sep 4, 2007 | 07:37 PM
mycar2fast's Avatar
so if i upped my boost to eight it would b fine??? im in michigan so whats that tell you as far as altitude??
Old Sep 4, 2007 | 07:56 PM
Ping King's Avatar
ive run 17 psi on a stock short block...its a crap shoot.
Old Sep 4, 2007 | 08:00 PM
vaticano's Avatar
i'd say go for it. just dont add to much timing
Old Sep 4, 2007 | 08:28 PM
wicked@boost's Avatar
8-9 psi no problem with a good tune, + looks like u need more fuel injector and that fuel pump wont survive .
Old Sep 4, 2007 | 08:42 PM
eLTwerker's Avatar
same for an LT1?
Old Sep 4, 2007 | 10:07 PM
FieroZ34's Avatar
I'd say go for about 45psi, and put a smaller throttle body on.
Old Sep 4, 2007 | 11:02 PM
ChevyChad's Avatar
that is a good approach also. But you'd still need meth, or at least some nitrous to assist with the intake velocity factors...
Old Sep 4, 2007 | 11:08 PM
FieroZ34's Avatar
It's a horrible approach, but that's my point. Another ignorant fool who thinks boost means everything.
Old Sep 5, 2007 | 12:00 AM
Josh@MASPORT's Avatar
Closed Sponsor Account
theres a sticky about making 8psi safely,
Old Sep 5, 2007 | 12:32 AM
98turbls1's Avatar
I'd say that 8psi can be had with a FMIC and a good tune... You can put the 6.0 heads on with some good springs (patriot are always a good option) for a safer barrier.. Anything over please go with some meth and don't cheap out on it... The best meth kit (which you'll use after the engine build) is still way cheaper than pulling the engine for a forged swap... especially when you don't have the money for that...
Old Sep 5, 2007 | 06:34 AM
ChevyChad's Avatar
geez, I know. I was just trying to give this guy a hard time because he made the same thread 19,562 other people have made. Okay, I guess I'm only amusing myself here...
Old Sep 5, 2007 | 08:13 AM
Boodyrider's Avatar
But dude, if 45 psi and a smaller throttle body works so well, how come you're only in the 12s?
To original poster... um, you need to do a LOT of research. Safe boost means proper tuning, and wideband O2 /egt tuning on the dyno means a lot more than "8 psi with a wiener wagger" vs "10 psi with a wiener wagger AND crack"
Also keep in mind that if you're doing this on a street car, pump gas varies GREATLY in it's quality and purity, and you won't be tuning for the weather... so conservative is the key.
Short answer... with a GOOD front mount intercooler, and good tuning, 8psi should be safe, if tuned carefully and conservatively.
You wanna make big power... start with the short block, and build it for the style you'll run, IE low compression / high boost, nitrous, NA. The ideal motor for each approach differs.
Old Sep 5, 2007 | 08:42 AM
ChevyChad's Avatar
I was in the 12 second club before I ever went FI. Haven't ever made a run with the procharger setup... All I've managed to do at the track with the procharger is break a driveshaft and a 10 bolt!
Old Sep 5, 2007 | 10:27 AM
will82's Avatar
From: Somewhere Between Mild Insanity and Complete Psychosis
7-8psi
or
10-12psi on meth
Old Sep 5, 2007 | 10:38 AM
FieroZ34's Avatar
Everyone here who has answered with a pressure knows not what they speak.
