pyrometer gauge or EGT
Old Sep 8, 2007 | 11:50 AM
Quik's Avatar
Default pyrometer gauge or EGT
was wondering if anyone is running a pyrometer gauge or EGT gauge along with A/F and boost gauges
bascially what gauges are most using
Old Sep 8, 2007 | 02:35 PM
Turbo LS1 SS's Avatar
boost and fuel psi are good to have. an airfuel and egt are also good ones to have if you dont mind the extra gauges. id place the sensor in your #7 primary as that is typically the first cylinder to go lean
Old Sep 8, 2007 | 02:39 PM
kbracing96's Avatar
I drilled and taped my manifold right before the turbo for a pyro last weekend. The sensor is installed, but I haven't wired it up to EFILive yet, but plan too.
Old Sep 8, 2007 | 02:46 PM
to add, an EGT gauge can be used for a number of things... seeing if something is going lean, knowing when your egt is optimal for boost, etc
Old Sep 8, 2007 | 10:10 PM
Quik's Avatar
yea i know a Pryo is a good gauge but wondering who and how many used them along with were they placed them
Old Sep 10, 2007 | 12:51 AM
2MuchRiceMakesMeSick's Avatar
I went with EGT bungs in all 8 of the primarys on my turbo manifolds.
I also have fuel pressure and the eboost2 has a build in boost gauge
Old Sep 10, 2007 | 07:07 AM
1INSANEGTO's Avatar
what EGT kit did you go with? I am looking to put 8 in mine
Old Sep 10, 2007 | 07:25 AM
ZL1Killa's Avatar
i run EGT on mine. I have EGT, boost, Fuel pressure, and working to get a permanent AFR gauge
Old Sep 10, 2007 | 11:47 AM
Quik's Avatar
do you use HPtuners? i know they have inputs for various types of sensors. i have my wideband wired up to the MVPI pro so it logs as we go. i was wondering if anyone logged teh EGT with the HPtuners or even fuel psi? i have a electric fuel psi guage but havent wired it up to the MVPI pro yet...not sure if i can
Old Sep 10, 2007 | 12:07 PM
Gauge's Avatar
11Second Club
Does EGT have any importance in a SC setup? Or is it really only important for turbos?
Old Sep 10, 2007 | 12:47 PM
kbracing96's Avatar
I could be mistaken, but I don't think HPT has inputs for K-type thermocouplers (EGT). I looked on there site real quick, but I couldn't find what all the input where. The other things you could log, as long as you could find some 0-5v senders for them.
Old Sep 10, 2007 | 01:19 PM
LASTLS1's Avatar
6 Second Club Moderator
A cheap set is $1000 a good set is $2400
Old Sep 22, 2007 | 01:48 PM
dhdenney's Avatar
I had planned on using a pyro in addition to a wideband.
Old Sep 22, 2007 | 03:51 PM
stevieturbo's Avatar
I have Greddy EGT installed in my no7 header tube...
VEMS offer a dual digital wideband/EGT gauge....very handy !!!
http://shop.vems.hu/catalog/product_...9d573da313f68a
This is a seller in Europe, but Im sure there are places in the US selling them ??
1INSANEGTO...
Ive also used Innovate's TC-4....it can handle 4 K type Thermocouples, and do the usual Innovate logging etc, as well as daisychaining with LC-1, or another TC-4 for 8 thermocouples.
Only used one when I was using it though. For a multiple EGT gauge, its pretty cheap.
