Twin A2W intercoolers Vs 1 Big A2W
The example being Twin 76's on a 408.
I can do Twin 1000Hp Intercoolers By Chisseld performance or a larger 2000 or 3000 hp unit.
i am thinking the packaging would be much easier mounting the intercoolers under the headlights and then making a 3" to 4" y to the Throttle body.
but most just Y- the turbo feeds togeather and use one big intercooler.
My buddy uses one PT3000 for twin GT47-88's on a 430ci motor
Keith
Keith
i cant see there being much differance. really this would be a problem if you had limited space, then you might need to go for a twin setup.
thanks Chris.
Also the pump would have to pretty big to suport two intercoolers. Splitting the coolant line between two intercoolers cuts down on the flow rate dramatically because the intercoolers are a restriction.
Keith
you may be right on the pump. but the cooler will always be a restirction to the pump. if the 2 coolers are big enough (half the size of the big core) then why will they restrict the pump more??
sorry for being stupid.
Chris.
Keith
Keith
Ummm Keith....... My Coolant in my radialtors have nothing to do with my A2W Intercooler setup.....
There two totaly different setups that neither rely on the other....
A single radiator that cools the motor... and thre a 5 gallin cell in the hatch that runs -20 line thru a marine pump in the hatch to the A2W intercooler and then back to the 5 gallon cell filled with ice water....
Piping comes off the turbo.... into the A2W intercooler and then back out to the TB.
BTW i would never even think about coolant as cooling an intake charge as you have written above..... reread what ya wrote... doesnt make sense...
Why would ya cool a 250-300 degree intake charge with 250 degree coolant???
My A2A setup was in the mid 120's-130 and my water is in the 60-70's.... on a 100 degree day.
Kyle
Keith
Keith
i don't think a Heat exchanger is really needed in a drag application since the run time is so short more ice can be added to system after each run keeping the temp consistent.
If this was a street car, or road race car then it would be absolutely necessary.
Keith
in an ideal situation you would have a chargcooler big enough to get the the intake air down to around ambient. now you would have to spec the rad (for the cooler) to beable to disipate MORE energy (heat) than what the chagecooler will 'make' (put into the water). this has no relation to what or how many chargecoolers you are running.
if you speck the cooler too small then you dont cool the air. if you spec the radiator too small then the water get hot and doesn't cool the air. basically you just need to make sure your 'system' is upto the task.
but this doens't answer the question on why 1 big charge cooler is better than 2?
thanks CHris.
Keith
I see you also asked the question on the NMRA board. Good choice.
Might try Hardcore5.0 too.
