Large Turbo > Thermostat Housing
Old 09-15-2007, 06:42 AM
KraZy's Avatar
Default Large Turbo > Thermostat Housing
I put the turbo in the area of the passenger side frame rail w/o regard to the thermostat housing.......
I found a straight housing on LS1 Speed's site but I believe this comes w/o a thermostat. What have you guys done to reroute this area?
THANKS!
Old 09-15-2007, 09:31 AM
smokinHawk's Avatar
i cut the neck of my thermostat and made it more of a right angle and rewelded it to avoid hitting my turbo.
you should be able to take the termostat and switch housings if thats what your talking about
Old 09-15-2007, 11:23 AM
KraZy's Avatar
I either need to cut it, or find the right thermostat works in the straight piece I found at Speed Inc
Probably w/ cutting it.....my MIG welder isnt going to like welding the aluminum
Old 09-17-2007, 07:31 AM
smokinHawk's Avatar
they do sell straight thermostat housings, but im not sure where been a while.
have you tried calling ls1 speed?
should just be able to swap the thermostat into the housing.
Old 09-17-2007, 01:00 PM
Jon @ Speed Inc's Avatar
A SBC t-stat will fit in the housings we sell (link)
On the turbo builds we do in house we do modify the housing to work with a factory t-stat as it tends to work better.
Old 09-17-2007, 02:37 PM
KraZy's Avatar
awesome, thanks guys
