High static compression and forced induction
I am building heads up street race car for the nmca with a 70mm turbo (max size limited to)
will be intercooled
I am putting a ton of compression in this thing 12.2 to 1 with 52 cc heads
my question is how am i going to keep from putting heads gaskets on this thing every weekend
as far as boost as much as it will make (how much timing will be safe)
My project is a 1968 Impala convertible SS427 (clone)
and I plan to run it with:
a 4l80E
3,08:1 12bolt Positraction (many of you will say why that high but I have just bought it that way and think my engine will have enough torque to move it and that way I have nice overdrive ratio because- Gasoline in Austria/Europe where I live, 1,95$ per liter!!!)
twin turbochargers
BBC 540cid mark IV rebuild, balanced and blueprinted
http://cgi.ebay.com/ebaymotors/ws/eB...3DR2%26fvi%3D1
with hydro roller cam setup and a Vortec 7400 EFI
Now my question:
If you read the description that engine will make 12,00:1 with closed chamber heads and 10,00:1 with open chamber heads.
I want to drive 95 octane and so the compression ratio will be to high for turbos.
Now I also ask if I get it done with a thicker head gasket.
I dont want to come toooo low with the compression as I dont want to loose my nice torque which would also cause more fuel consumption in the daily stop and go traffic. I think about relaxed 9,0-9,3:1 compression and only a mild boost to give an additional punch in the mid and high range when my tire slipage is already over and I have traction again.
Is it done with a thicker gasket and a lower boost pressure and what pressure would you recommend?
Any camshaft recommendation for a BBC stroker with:
Twinturbos
EFI
which only got low boost preasure
high torque
and which shall not need unnecessary much gasoline (I know it will not take less but evan by a big displacement engine there is a window from -until and I would prefer to be on the lowest possible point with that setup)
If you have a recommendation please state all specs I need for an order as I am not a cam specialist. I am advised and supported by a friend and dragracer but he dont want to believe that a EFI engine never got that radical cams as a carb engine (at least I was told so at www.raylarengine.com, I was in contact with them as my first engine for that project was a Vortec 496).
Any help highly appreciated
Hannes
You want to lower the compression with new pistons NOT headgaskets.
Keep it around 9:1 to make it pump gas safe.
With 540 cubic inches I'm sure you'll have PLENTY of torque.
I am skeptical to buy things off ebay. I would contact a known engine builder like Shafiroff or Nelson Racing engines. You'll need to tell them what size turbos you are running and they can design the engine around that criteria.
good luck .
For my opinion I made a very nice deal and this guy got a usual shop outside of eBay, it is not a private seller.
He got a lot of positive feedbacks.
10:1 is 10:1 whit what pistons does not matter. I ask the same question than the thread starter did: Can I come low enought with a thicker gasket.
And like him, I also try to keep high enough with the compression to keep my low end tourqe and only to give just a little boost to make my
engine more punchy in the mid and high range.
By the way, do you know Nelsons video 66´Impala 572cid for jerry covington (see it at www.nelsonracingengines.com).
Sorry to say but he says at that video that the Impala got 5000+pounds.
I have a 68 Impala what is the same body (65-70 Impala/Caprice/Bel Air/Del Ray), it is the convertible and therefor more heavy as it got a stiffer frame to compensate the missing roof and it only got 3750 pounds.
Such a light car (for me it is not that heavy for the size) with that displacement and a 6speed???
What nonsense 572-6speed. I am sure Nelson took thousend of dollar for building that car but that for I dont need a pro.
He also run biiiig engines only on 9,0:1, sorry bit I have another opinion. Usual street cars with aspirated engines using pump gas should drive 10,0-10,5:1 to have efficient power.
Else I take a smaller one with higher comparession.
Thanks Hannes
Setup is forged 408, ~11.7:1 with -1.5cc dish pistons and fully ported 5.3 heads (73cc chambers).. Im looking at going l92 top end, but not sure what that would do to my compression. Ill be converting to E85 regardless and im told it allows for more forgiveness with a tune. I JUST built this engine and would like to do this without replacing pistons right away if I possible. Anyone?
FWIW, I am an advocate of higher CR
