View Poll Results: what compression ratio are your running with boost?
8:1
8
2.92%
8.5:1
44
16.06%
9:1
55
20.07%
9.5:1
69
25.18%
10:1
66
24.09%
11:1
32
11.68%
Voters: 274. You may not vote on this poll
High static compression and forced induction
Old Nov 28, 2008 | 03:14 PM
  #121
DanZ28's Avatar
Is anyone running a high CR with E85 and 20+ psi?
Old Nov 28, 2008 | 07:59 PM
  #122
vaticano's Avatar
Originally Posted by NemesisC5
How much does E85 cost per gallon? I'd like to see the result of the CR bump going from 11.4:1 compared to 13:1
FWIW, I am an advocate of higher CR
Currently it is $1.60 a gallon, last time I filled up.
Old Dec 1, 2008 | 02:53 PM
  #123
No Juice's Avatar
Corn was $1.35/gal today and regular 87oct was $1.75/gal
Old Mar 5, 2009 | 03:55 PM
  #124
Cmarsh's Avatar
I just did a vette with 11:1 compression and a vortech. with only 4psi, it made 630rwhp and had crazy power under the curve. Throttle response was really good too..just required a good tune
Old Mar 5, 2009 | 04:51 PM
  #125
Got Me SOM's Avatar
I bet it runs great, sucks that you cant run more boost without meth.
my old vortech car with 10:1 compression ran great, great throttle response with boost. I ran 9 psi on the stock bottom end. Went consistent 11.2's full weight with drag radials on the stock rims, and just lca's.
Old Mar 5, 2009 | 05:11 PM
  #126
LS1x2's Avatar
Formerly 4mulaJoe
10.5:1 stock bottom end with 13psi here. 93 octane, but i'm spraying a 50/50 mix of methanol also. 15* timing so far (took 22 max NA), but it seems like I could add a little more.
Old Mar 5, 2009 | 07:53 PM
  #127
NemesisC5's Avatar
With my AFR 205's and .040 Cometics my CR is around 10.3....I run Shell 93 with one can of Torco in each tank & 100% meth spraying as well. My timing is at 21*, increased it to 22* and lost a few HP....so with my particular combination 21* is my MBT (mean best timing)
Old Mar 5, 2009 | 08:05 PM
  #128
LS1x2's Avatar
Formerly 4mulaJoe
Wow! That meth is really helping out. The ls6 heads make all the difference between our 2 setups though. Even when stock on 93 octane they would only allow for 22-23* timing before pinging.
Old Apr 8, 2009 | 06:02 PM
  #129
bifster's Avatar
WOW ! 1.5 yrs in the making this post has given me alot to read about hahaha . thanks guys for all the feedback and the numbers I knew this has been a longtime question for many and im sure this will help alot of those guys out there that think they need to run 4:1 compression to run awsome numbers.
as for the original shop iwas working with to start at this thread they became alcohol junkies and now they run something like 15:1 and 25lbs through a BDS LOL but i dont have the 30K they dropped into there engine to put into my street car haha. anyways thanks a million for all the replies really has helped me out with my build that im running 10:1 now on my stock bottom end and 15 lbs with meth. car runs strong never had a dyno or a tune other then the seat of my pants thankfully i havent detonated the pistons through the oil pan so far guess my eyes work well still.. all the best
keep moving forward 1/4 mile at a time!
Old May 22, 2009 | 07:41 AM
  #130
dreamls1's Avatar
I am running 10.28 to 1. 11psi. goes on the dyno next week, will see how it does.
Old Feb 2, 2011 | 01:22 PM
  #131
AmericanMuscle313's Avatar
Bringing it back from the dead...
Is High SCR and a better option with the (newish) TVS 2300 maggie ? I see builds with people putting the tvs 2300 on stock LS7's with 11:1.
Old Feb 2, 2011 | 02:39 PM
  #132
mulletnotch's Avatar
I will be reporting results of E85 fueled and twin turbo at a bit over 11:1 pretty soon. Hoping to make an easy 850-900rwhp.... We'll see.
Old Feb 2, 2011 | 03:17 PM
  #133
Tirefire's Avatar
AES 390, TF as cast heads 62 cc I believe 233/240 cam=9:6:1. How much boost will I be able to get away with on pump gas? (Twin Intercoolers). Any help greatly appreciated.
Old Feb 7, 2011 | 12:12 PM
  #134
How much boost? Dunno. But you'll be able to make somewhere around 600-650rwhp on pump with a good tune.... Boost is relative and varies based on how well your engine breathes or doesn't. Should be able to make 600 no problem and with the heads you've got maybe closer to 650.
My opinion of course.
Old Feb 7, 2011 | 12:38 PM
  #135
Phil99vette's Avatar
7 Second Club
Is E98 or E85 available?
Old Feb 7, 2011 | 07:50 PM
  #136
Tirefire's Avatar
No corn out here El Paso, TX!! I was hoping for more power on pump gas since I'm putting down 525 rwhp already? Or at least that's what it said on the dyno sheet I got when I got the car back from the shop I sent it out to. Oh well I'll probably go with meth to get a little more power!!
Old Feb 8, 2011 | 01:27 AM
  #137
AES Racing's Avatar
TFS 220 as cast heads are 65cc chamber
I've had someone make 685rwhp through twin intercoolers LS 347ci 10:1, D1SC at 12psi.
That setup did get some detonation on pump fuel, IATs were fine though.
Old Feb 8, 2011 | 05:05 PM
  #138
Tirefire's Avatar
Those numbers are solid with twin intercoolers!! That will give me time to purchase a front mount and meth later down the road. Like KP told me "small steps"!! Hey Fraser so what's my final compression looking like on my block? I was under the impression that it was 9:6:1, I thought those heads were 62 cc.
Old Feb 10, 2011 | 03:00 AM
  #139
1SlowHoe's Avatar
Destroyer of Transmissions
Default 10.4:1 and boosted
I want in on this discussion because I have heard so MANY conflicting stories about my build. Upgrading the Family Truckster (2002 Tahoe)
Here is the down and dirty.
Iron 408cid*, -3cc pistons, WCCH worked LSA heads with 75CC chambers, LS9 gaskets (.051 I hear), TVS2300/jackshaft/cogged rear/10 rib setup/ should easily make @12-15psi.
My cam was spec’d by PatG and the CR’s were:
Static compression: 10.4:1
Dynamic compression 7.50:1
Gas is 92 Octane and meth kit can spray whatever mix deemed necessary. Was thinking 50/50 water and meth but 100% meth is fine too.
So you guys say “No way!” or “Sure, but you’re going to be pulling timing up top”
I'm just asking your thoughts. The engine is built, the blower is ordered. Should be together and on the dyno in March sometime...hopefully.
*(The engine is all forged Eagle crank/rods Aries Pistons, all ARP hardware.)
Old Feb 17, 2011 | 06:47 PM
  #140
Milfordfab's Avatar
Default E85 - The Poor Man's Race Fuel
Gentleman, I currently work for someone involved in advanced engine developement. Trust me, E85 works well in an 11 to 1 engine with leaner mixtures and more timing than pump gas at high boost levels. It also makes 10 to 15% more power due to the higher cylinder pressure developed by the additional timing and leaner mixture. Plus it's cheeper than regular gas and makes lower emmisions. Why would you want to use premium pump gas anymore???
