View Poll Results: what compression ratio are your running with boost?
8:1
8
2.92%
8.5:1
44
16.06%
9:1
55
20.07%
9.5:1
69
25.18%
10:1
66
24.09%
11:1
32
11.68%
Voters: 274. You may not vote on this poll
High static compression and forced induction
Old Feb 17, 2011 | 08:10 PM
  #141
NemeSS's Avatar
Because it's not readily available in alot of places yet or at all.
I would rather run 9:1 so I have capacity to run up to 15psig on pump octane
Old Feb 17, 2011 | 10:41 PM
  #142
1SlowHoe's Avatar
Destroyer of Transmissions
I’ve had a flex fuel truck for 7 years. I have NEVER seen E85 at any pump from Fl to Ok. Where do they have E85? Just Nebraska?
Old Feb 17, 2011 | 11:00 PM
  #143
52172's Avatar
I run 9.8:1 compression with 10-12lbs boost and shitty 91 octane gas without any problems and over 10k hard street miles its all in the tune! I know I'm at only 17 deg timing max and a rich 10.7 afr....
Old Feb 19, 2011 | 03:40 AM
  #144
S2VYSS's Avatar
Originally Posted by AES Racing
TFS 220 as cast heads are 65cc chamber
I've had someone make 685rwhp through twin intercoolers LS 347ci 10:1, D1SC at 12psi.
That setup did get some detonation on pump fuel, IATs were fine though.
Was that on a built bottom end?
Do people think you could get away with 11:1 comp with a PD blower on E85 without too many problems?
Old Feb 20, 2011 | 12:58 AM
  #145
1evilss's Avatar
Hey guys im trying to figure out if im gonna be ok with a 10:1 CR on a 402 that gets 93 octane but may switch to e85 ......Also what kinda boost would I be able to run safely? Keep in mind this will be my street/weekend warrior....Car usually sees about 600 miles a summer
