stainless steel vs mild steel vs aluminized
Old 09-23-2007, 02:23 PM
RooRnZ28's Avatar
Default stainless steel vs mild steel vs aluminized
Hey guys.. i have been trying to get my exhaust fixed for the past few months, and i have come across all these different types of piping: stainless steel, mild steel, and aluminized.
aluminized seems to be the most popular around where i live, as every exhaust shop uses it, so whats so good about it, if anything?
I know stainless doesn't rust, which is what i was pushing towards but it is a little more expensive...
i want to replace piping from my header collectors, back to my turbo. the first shop i took it to screwed it up pretty good
i have an SLP Y made from Stainless, so i was thinking of just doing all stainless... but will it eventually crack if i wrap it with heat wrap?
what are the pros/cons of the 3 types? thanks...
Old 09-23-2007, 06:13 PM
ninetres's Avatar
Don't you have friends in Fresno who can help you???? Cough cough.
Old 09-23-2007, 06:41 PM
smokinHawk's Avatar
it all depends on how much you want to spend, stainless would be the best but most expensive.
aluminized will work ok and resist rust. i wouldnt get mild, unless you had it ceramic coated.
i used aluminized for my hot parts and it is holding up fine
Old 09-24-2007, 02:55 PM
RooRnZ28's Avatar
lol... you were the first one i went to!! i had talked to your mechanic a few times, but he didn't call back. he seemd pretty busy....
well it looks like stainless for me, thanks smokinhawk!
Old 09-24-2007, 03:01 PM
SonofaBish's Avatar
+1 for aluminized... everything on my car is stainless and you don't wanna know the eventual cost
Old 09-24-2007, 04:15 PM
Incognito's Avatar
aluminized or coated mild
both are less expensive then stainless.
coated will despense heat as good or better then stainless.
The biggest bennifit to non stainless is the weight savings. Stainless is HEAVY!
Old 09-24-2007, 08:10 PM
RooRnZ28's Avatar
well is there any benefit to coated stainless?
Old 10-02-2007, 04:51 PM
Reject's Avatar
coated with ceramic coating mild steel would be better than Stainless steel?
Old 10-02-2007, 05:10 PM
7 Second Club
Phil99vette's Avatar
I'd go mild steel with ceramic coating. I found a place that has MS U bends CHEAP and I mean CHEEAAAPPPP.
Phil
Old 10-02-2007, 08:17 PM
LS1Tech Sponsor
hellbents10's Avatar
Where????
Old 10-02-2007, 08:54 PM
7 Second Club
Originally Posted by hellbents10
Where????
The place is in either NC or SC, pro-formance fabrication. $9 bucks for a 1 7/8 or 1 3/4" u bend.
Old 10-02-2007, 09:03 PM
Reject's Avatar
link?
Old 10-03-2007, 06:06 AM
Fireball's Avatar
stainless....
regular steel will eventually rot from the inside out...in regards to coating....most coatings I've ever seen eventually flake off...remember you are going to be dealing with high temp/pressure exhaust gas from the header to turbo...that'll wear it down over time
Old 10-03-2007, 09:33 AM
Reject's Avatar
do you have an idea how long it will take?
i was looking at Na$ty's build up and his are coated arnt they?
Old 10-03-2007, 10:06 AM
DMH Fabrication's Avatar
yes his hot parts are coated from what i remember
Old 10-03-2007, 01:08 PM
PM me some info if you have a contact number or website for them. Thats about half of what I normally pay. Thanks!
Old 10-04-2007, 09:09 PM
7 Second Club
profabrication
They list the steel for $10 and the SS for $30, when you call they always give you a discount.
Old 10-04-2007, 09:12 PM
Reject's Avatar
sweet. do you have to ask for the discount or hint it to them when ordering?
Old 10-04-2007, 10:26 PM
Thanks Phil!
Old 10-05-2007, 01:19 AM
ODB
ODB's Avatar
id go with inconel, it may cost you a fortune but it will most likely last longer then your entire car
Quick Reply: stainless steel vs mild steel vs aluminized
