Is a Ported 90/90 set-up worth it for FI?????
Old Oct 16, 2007 | 01:52 PM
speedracer5532's Avatar
Originally Posted by Gauge
If price was no object, what would you guys pick between LS6 w/ ported TB and LS2 w/ ported 90mm TB? I will go Procharger in the future, and I may have the opportunity to pick up an LS2 intake for free.
If money is no object then why not go Ported 90mm FAST.
Old Oct 16, 2007 | 03:41 PM
dixonk's Avatar
Originally Posted by TaShOo
ASKE gasem a bout my car, your steup is almost like mine
weth tha FAST you will leak 14psi +
good luck man,,, wish you the best
I guess it is different for everyone. I was pushing 17psi on mine and no problems. I did pick up a victor jr. today though just one less thing to worry about I guess.
Old Oct 16, 2007 | 03:48 PM
Agree, I have ran 18 psi through my FAST with no problems.
Old Oct 16, 2007 | 04:53 PM
kp's Avatar
kp
FWIW I switched between a FAST 90/90 and the LS6/ported stock throttle body several times and there was no difference either way. Sold it and spent the money on a good set of heads that did make a difference.
But now with bigger heads/cam I'm using sometimes I think of trying the fast again, got to be worth .011 in the 1/4, maybe
Old Oct 16, 2007 | 05:07 PM
STP's Avatar
STP
75mm throttle body and a ls6 intake works fine for me makes 1162hp at wheels.
Old Oct 16, 2007 | 06:30 PM
stevieturbo's Avatar
Which way though
Old Oct 16, 2007 | 06:40 PM
67Firebird455's Avatar
Holy crap that's a grip. What kind of boost?
Old Oct 16, 2007 | 06:48 PM
The Aussies run a car that does low 8's, at 160+ using a stock LS6 intake and TB too.
Old Oct 16, 2007 | 07:29 PM
kp's Avatar
kp
Which way though
heh, not going to spend 1000.00 again to find out
I still have the throttle body, may try an LS2 intake if I can find one cheap for grins.
Old Oct 17, 2007 | 04:37 PM
Big Bird WS6's Avatar
well if money is not an issue. then what about a wilson sheet metal manifold. please any info on this would be nice
Old Oct 17, 2007 | 07:08 PM
njc.corp's Avatar
Cool
i would say 1 thing that i and everyone knows about the new wilson sheetmetal intake- it looks trick and is pure sex- comes with a nice price tag-
i did recall katech doing back to back test in a n/a form engine against a fast 90/90 and they came up with a zero hp or trq gain- dont know why it did not perform
so by having a guess-the sheetmetal would be good for 4 things- 1- looks
2-big cubes 3-big cubes and turbo or turbo's 4. no 3 and a lot of rpms
i was going to pay the 3 k until i found out katech did not get a gain-
so i kept and i am still using my fast 90-if i was really rich i would just buy the wilson one for looks-but i am not-
i am also suprised since i joined this forum that heaps of threads report people getting big hp+torq+ and good et's out of the ls6 intake
so i am very suprised also that the ls6 performs so well in the fi department-
i was also under the impression that a better intake would gain more or perform better than a standard factory item-not in some cases as i have come'ed to understand-
Old Oct 18, 2007 | 11:11 AM
  #32
MY99TAWS6's Avatar
Since you are forcing the air thru it can compensate for not as good flowing heads and intake. But you should be able to make same power at lower boost level with better heads and intake. There are also other reasons to go with different heads and intake. I like the option of direct port on my fast intake.
There have been sizable dyno gains NA on the dyno section especially from ported fast 90 combos.
Old Oct 18, 2007 | 11:19 AM
  #33
Websy21's Avatar
now thats reassuring b/c thats what I'll be using too
Old Oct 18, 2007 | 11:21 AM
  #34
Websy21's Avatar
maybe its enough to get you into the 8's Kevin. I wonder if trap would improve a bit even though dyno numbers don't make much difference if this 'has' been proven
Old Oct 18, 2007 | 12:08 PM
  #35
kp's Avatar
kp
Maybe, but if I really wanted to get in the 8s a 90.00 pulley is a more of a sure bet than a 1000.00 intake at this point.
I'm not trying to discourage anyone from buying or using one, using one certainly cant hurt and if you have the $$ to spend it looks better than a stocker at least..
Old Oct 18, 2007 | 12:18 PM
  #36
Websy21's Avatar
ya i hear, wish the funds were unlimited, lol
Old Oct 18, 2007 | 02:48 PM
  #37
n/a results dont always have relevance to FI results though. AFAIK, most FI dyno results say FAST 90 is a waste of money.
