Supercharged LS2...Can I lower compression and up boost?
Old Oct 11, 2007 | 12:01 PM
Piersin's Avatar
Default Supercharged LS2...Can I lower compression and up boost?
I have a supercharged stock LS2 making about 500rwhp.
I was thinking about adding 72cc heads to lower the compression to around 9.6 or so. Right now it's about 7lbs of boost. Can I turn it up to 10lbs after?
Old Oct 11, 2007 | 12:05 PM
Inspector12's Avatar
TT-TECH Veteran
Yeah it works good. Although I know of a lot of LS2's putting more boost than what you have without any issues. I did that on my stocker a long time ago so it is one way to get more power while staying on 93 etc... although I don't think you should really have to worry until @ 10lbs.
