8 rib drive system for procharger
Old Jun 10, 2003 | 10:54 PM
GPowrie's Avatar
Default 8 rib drive system for procharger
I am wanting to find out who is selling these systems and what they include. I am wanting to run 15 psi. plus boost with a F1 head unit.
Old Jun 11, 2003 | 12:26 AM
BIGBOS's Avatar
Default Re: 8 rib drive system for procharger
I am going to be running ASP's 7.85" crank pulley 8 rib, and Reichard Racings 3.60" 8 rib blower pulley...I'm looking for 12psi...
Scott WS6 is using these pulleys too and so far hasn't broken any more belts and there is no slip...
Old Jun 11, 2003 | 07:13 AM
10.5 Dave's Avatar
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
Scott ws6 has broken belts with his setup just not as often.Anyone running high boost with a belt will break belts,its just a matter of how frequently.Scotts setup seems the best so far.
Old Jun 11, 2003 | 10:28 AM
GPowrie's Avatar
Is the asp pulley made for this application or is a pulley for something else. Also do you have their web address and part number. Thanks for the help.
Old Jun 11, 2003 | 12:12 PM
BIGBOS's Avatar
I don't think there are part #'s, but
ASP's phone # is 1-877-928-8678
If you decide to have them make your crank pulley, your going to have to send in a stock crank pulley so they can line it up so it doesn't wobble once you put it on the car...
I forgot RR's #, but the website I believe is reichardracing.com
Old Jun 11, 2003 | 08:11 PM
scottywheels's Avatar
i run a set up that doesnt slip and i havent broken a belt since installing the big ati race valve. If you want any info then PM me. thanks
scotty
Old Jun 11, 2003 | 08:14 PM
BIGBOS's Avatar
Scott how do you like that race valve...?
Old Jun 11, 2003 | 08:52 PM
GPowrie's Avatar
Thanks for the info BIGBOS.
Old Jun 12, 2003 | 01:51 AM
the race valve is awesome, it sounds like a mac truck when I let off.
Gpowrie, what are you doing for a motor, that is going to make a huge difference in what you need to see that 15 psi.
Old Jun 12, 2003 | 09:40 AM
GPowrie's Avatar
The motor is going to be forged bottom end 346. I am going with 6L truck heads that will flow 320+. The motor will also be solid roller. I am shooting to get around 8.5:1 compression. I realize with the low compression, high flow numbers on the heads, and the big solid roller cam it will be more diffuclut to make high boost. I would honestly like to see more boost than 15 psi. but I know that at some point the factory computer will no longer get the job done.
Old Jun 12, 2003 | 01:49 PM
Nickn20's Avatar
boost does not matter! its all about airflow. MAKE that motor see 15 psi, tuned right you will have 700rwhp with a 6 speed car.
