Help with Turbo selection.
Old Oct 24, 2007 | 09:58 PM
1998TA__1991RS's Avatar
Default Help with Turbo selection.
I'm going to be running a custom single kit on a stock LS2. I only want to make about 7-8psi with daily use, and about 550rwhp. what size single should i go with, and what brand? I want to try to buy the turbo for $600 or less. Thanks.
Old Oct 24, 2007 | 11:21 PM
menlatin's Avatar
master t70? right around $600 from forced inductions, if they still carry them.
sounds like you're doing front mount, so i guess .96 A/R. Thats what i've been planning for my 430hp sbc.
actually, second thought, maybe a .84/.81 A/R for quick street spoolup.
Old Oct 24, 2007 | 11:30 PM
im actually doing a low mount on a trailblazer ss, the turbo will be placed right below the bellhousing on the trans.
I also found a good deal on a New Garrett T04B90 would this be ok for a low boost application? the compressor is a .60 and the turbine is a .96
Old Oct 25, 2007 | 12:00 AM
i also found this one, i think its a powerstroke turbo, its new and cheap, anyone know anything about it?
Old Oct 25, 2007 | 12:18 AM
menlatin's Avatar
The T04B will not flow enough for what you want. I'm not positive about the power stroke one, but i dont think it flows enough either.
Everyone is going to tell you not to try and skimp on a turbo, as most ppl end up paying double when its all said and done.
Also, stay away from any remarkably priced no-name ebay turbos.
Old Oct 25, 2007 | 01:00 AM
i've been doing alot of reading tonight and i think im either going to go with the borg warner s400 or a master pro t70
Old Oct 25, 2007 | 11:34 AM
anyone else have any input?
Old Oct 25, 2007 | 04:19 PM
ttt...
