A2W intercooler hoses
Old Oct 27, 2007 | 11:45 AM
Phil99vette's Avatar
7 Second Club
Default A2W intercooler hoses
Anyone have a trick hose they like for the water transfer? What size hoes do you guys run and which intercooler core do you use?
Old Oct 27, 2007 | 12:01 PM
NA$TY-TA's Avatar
Phil we use 3/4" Rad. Hose with the brabed AN Fittings with Hose clamps.
Same thing with my PTE 1800 i have now and my Buddy's PTE3000.
Ill snap some pics for ya when i go by there...
Rad Hose is WAYYY cheaper then AN Hose and we havent had any problems with it.
Kyle
Old Oct 31, 2007 | 09:41 AM
7 Second Club
T T T, need to find some 1.25" hoses, min 1".
Phil
Old Oct 31, 2007 | 09:52 AM
ALLBOTTLE's Avatar
LS1TECH Sponsor
http://www.anver.com/document/vacuum.../hs-series.htm
This Is what i've seen alot of guys run, it' doesn't crimp under tight radius and you can see the fluids running through it.
from 1/4"-2"
Old Oct 31, 2007 | 11:15 AM
eliotmansfield's Avatar
I use something very similar to the above, except that its black and is used for pumping water around ponds, which means its pretty cheap also.
Only issue, is that your fittings must match the OD exactly, because it doesn't squash very well.
Its like this:
http://www.aquaticbiotope.co.uk/Scri...idproduct=1499
Old Oct 31, 2007 | 12:33 PM
GTFORMULA's Avatar
I also used 3/4 hose but mine is pushlock style. On along pull my inlet temps only get up to 65 degrees with ice in the tank.
Old Oct 31, 2007 | 12:39 PM
7 Second Club
What intercoolers are you guys running? The latest garrett cores requires ALOT of water. 55+ GPM.
Phil
Old Oct 31, 2007 | 01:00 PM
GTFORMULA's Avatar
I have two ebay A2W intercoolers the I cut the end tanks in half and welded together to make one big frontmount intercooler.
