what computer mods w/turbo???
what kind of computer mods do you do, or have w/ the turbo?, and how much boost can you go safely with the stock programming?, I heard somewhere around 11psi is max w/ stock computer, also what kind of injectors and plugs are you running?, thanks........
Re: what computer mods w/turbo???
you need to get it reprogramed with ls1 edit.
I wouldnt go more then 6psi with stock programing or with out high octane.
injectors you need depend on how much HP you making. right now im running 42lb svo's and will be installing 55lb danka/semian.
most people use ngk tr6 gapped around .35 or at most .30-.40
