Does running E85 affect turbo sizing?
Old Nov 19, 2007 | 03:27 PM
y2khawk's Avatar
not exactly.
air in may be the same, but fuel usage is way up. You burn it, it turns into something mass wise. Gotta go out the exhaust.
Old Nov 19, 2007 | 04:26 PM
camaroandreas's Avatar
We always get more power with E85 then gasoline, and less backpressure.
Tested several times..
Old Nov 19, 2007 | 05:06 PM
DuronClocker's Avatar
Originally Posted by y2khawk
not exactly.
Right, but it is also cooler, so velocity wouldn't be as high as the same amount of gasoline burned, so it wouldn't exactly be a 30% difference in exhaust requirements, but I could understand there being a difference.
This wouldn't impact the requirements for the cold side of the turbo in any way though, right?
Old Nov 19, 2007 | 05:26 PM
DrTurbo's Avatar
LS1TECH Sponsor
No the compressor side requirements can stay the same, but just the exhaust side needs to be compensated for.
Old Nov 19, 2007 | 06:21 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by mahhddgtp
And I expected it to work out like this
My statement about fuel volume being irrelevant was directly related only to the compressor side, which Drturbo states would stay the same.
Old Nov 19, 2007 | 07:05 PM
Makes sense! Cool!
Old Nov 19, 2007 | 08:00 PM
mahhddgtp's Avatar
I caught on after a while. I was talking Turbine.
Old Nov 19, 2007 | 08:03 PM
Tiago's Avatar
interesting, now Houston needs to have more E85 stations so I can convert.
