Procharger guys. Come inside please!
Pinning the crank is a must, just get some extra bits. And a 12 pk! Oh, and get a solid tensioner for the main belt too (K tech?). I threw mine at the track & it took out the PS hoses. But I have had no issues since.
I am now installing one of EPPs FMICs & twin Walbros. Fuel pressure & air temps ARE an issue when you turn the boost up.
Keep reading here & talk to Bob & you'll be fine.....
Seriously though call Bob@EPP with all you Procharger questions-he's the man!!!! Bob I hear there's F1R heading our way!!!!!!
Not the same as the ProCharger 8-rib kit (which EPP sells). The procharger version does not have a spring tensioner, its a manual tensioner same as the 6-rib kit, just wider pulleys. I am running the procharger kit personally and have not had any problems up to 15psi. I know EPP uses this setup all the time as well with great results. This kit uses a 7.65" crank pulley BTW...
Yes- you need the ATI damper with either kit...
3 head units in 2 years? Something does not sound right. I am sure it wasn't Prochargers fault either.
The bigger air filter did indeed get me 1.5~2psi on my old P1 setup. Highly recommended. And at less than $50 it may have been the cheapest mod I've done with the biggest impact!
BOSS APPROVED!
