Please HELP
Old Nov 26, 2007 | 08:01 AM
Fahad's Avatar
Default Please HELP
Hi everyone, what do you think about this turbo kit? it's for F-bodies 98-02
Here's the specs of the kit:
1 x T61 T4 Turbocharger (rated to 600 HP)
1 x 38mm Billet Aluminum Wastegate with all fittings
1 x Custom Intercooler w/ 3" inlet and 3" outlet
1 x Mandrel Bent, Tig-welded and coated Tubular Exhaust Manifold - Driver Side
1 x Mandrel Bent, Tig-welded and coated Tubular Exhaust Manifold - Passenger Side
1 x Mandrel Bent, Tig-welded and coated 3" Downpipe w/ wastegate recirculating flange
1 x Mandrel Bent, Tig-welded and coated 3" Downpipe that bolts to the previous downpipe
2 x Mandrel Bent Cross-over pipes
1 x T4 Turbo Mount with Wastegate flange
2 x "Y" Pipes that bolt to the factory or aftermarket exhaust
1 x Radiator hardpipe - your old hardpipe will not fit with the kit, we include a new one that will work. All necessary V-band clamps
Thanks in advance.
Old Nov 26, 2007 | 08:54 AM
nesikachad's Avatar
pretty
Old Nov 26, 2007 | 09:01 AM
hellbents10's Avatar
LS1Tech Sponsor
Do a search. The Turbo is by no means good, some have said the hot pipes are really nice though.
2002 Trans Am's Avatar
I've seen that picture before....Ebay?
From what I recall, the Ebay kits are just a ripoff design of I believe a TTI kit. Except the Ebay kit comes with shitty turbos.
Old Nov 26, 2007 | 09:13 AM
Hennytime's Avatar
400 bucks does seem too bad for the kit. i would try it, but first replace it wit ha better turbo. any idea if that kit can fit a t76 on at4 flange if it is a ripoff of the tti kit? only way i could justify anyone buying it
Old Nov 26, 2007 | 02:22 PM
SUPERBOOST's Avatar
I don't know if thats correct but if you just paid $400 for it, it has to be worth that.Just replace the turbo and check all the mounting flanges to see if they are true and go for it.You could not even begin to build it yourself for that.
Old Nov 27, 2007 | 06:00 AM
Fahad's Avatar
Yes it's looking pretty. correct he is from Ebay.
I already do a search but i coudn't find anything!! also the owner of that kit doesn't have a contact number or website!! just PM at Ebay.
Replace the turbo that is my first plan.
400 bucks he have sold same that kit but for Corvette C5 about $1500
I see there agood question, any idea if that kit can fit a T76 on a T4??
Old Nov 27, 2007 | 08:09 AM
SUPERBOOST's Avatar
I thought that sounded a little bit too cheap!Anyway, the hot parts are supposed to be pretty good judging from former disscussions on this kit .A couple of guys on the board have this kit but I dont remember who they were,mabye somone else will.Something to do with the disscussion on this was locked,mabye because of non sponsership,perhaps a modereator will say why.I think a t4 76 will fit but there are certainly no guarantees on this kit.Still seems like its worth the money just for the hot parts.You can try a search on ebay kit but I dont know how much good it will do.Mabey the guy who has one will chime in.
Old Nov 27, 2007 | 10:33 AM
DrTurbo's Avatar
LS1TECH Sponsor
We have had customers buy that kit and then buy a TC76 to go with it. I have yet to hear how fitment is with that kit though.
