gotta ask.............
Old Nov 28, 2007 | 09:47 AM
Quickin's Avatar
Originally Posted by Mekkadon
Well, there are some Viper owners that would say otherwise
He can always turn the boost down if it's too much for the street.....right?
My friends Viper has over 1,300 RWHP and its perfect for DD....PERFECT....and it kicks everythings *** it races.
Old Nov 28, 2007 | 10:10 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Fact of the matter is, if you are going to use NRE, I'm sure he has very clear thoughts on what combo he would suggest, he's built a lot of turbo cars.
If you plan on running a 408 - 427 - 454, you will need to run between a 98 - 101 mm turbo. You will need 160 lb injectors, or two fuel systems, a BS3, and a lot of custom fabrication. With some thinking put into it, I could have someone help me fit a 98 mm turbo with my current setup but some stuff would have to be moved around or changed.
Honestly as I'm typing this I think you should focus on a 408/427/454 and twin 72-76 mm turbos. I don't think you will ever package a big thumper with a/c in the engine compartment of a 4th gen.
NRE F-Bomb:
Old Nov 28, 2007 | 10:17 AM
1INSANEGTO's Avatar
Dr Turbo can you get this new unit in a .90 and 1.00 A/R That would be a sick combo for a built 408ci,
Old Nov 28, 2007 | 10:35 AM
98Z28MASS's Avatar
I still like the original idea of the TT BBC, that would make for a HUGE hp unique showcar.
Old Nov 28, 2007 | 10:36 AM
98Z28MASS's Avatar
Also, if you really need AC, just install nitrous jets behind your dash and when it gets hot have a purge button that will run the N20 though the vents, instant cool!
Old Nov 28, 2007 | 10:47 AM
Carnutz's Avatar
Originally Posted by DrTurbo
Yes the S91 is smaller and closer to a GT42 chassis. The FI-X chassis is closer to the GT55 which is larger overall. As for fitting on a OFI kit, that would be up to Joel. These units spool much quicker then the larger thumpers, and put down awesome numbers.
So can I use a GT55 as a mock up turbo to finish building the headers? (Is it close enough size wise?) And Jose? answer the phone!!! Lol
Oh and PSJ, we will see what all can be fitted into the nose of a 4th gen
Old Nov 28, 2007 | 11:11 AM
DrTurbo's Avatar
LS1TECH Sponsor
All the way down to a .85A/R
Old Nov 28, 2007 | 11:12 AM
DrTurbo's Avatar
LS1TECH Sponsor
Phone is ringing off the damn hook.
I thought the holidays would slow things down?? ...................guess I got owned.
Old Nov 28, 2007 | 11:22 AM
1INSANEGTO's Avatar
.85 A/R Damn.... Talk about a quick spooling turbo!!!!!!!!!!!!!!!!!!
Anyone know the size of GT55.. Tall, inlet, outlet etc?
I have a friend who has a large frame 88MM turbo. Not sure if that is a GT55 frame or not....
I have a Airearch 83MM now which is a GT42 frame. I want to see if I can fit it all with the T88 Large frame if in fact it is a GT55 frame and just run the 83MM GT42 frame till we get the funds for the new one.
Old Nov 28, 2007 | 11:27 AM
Quickin's Avatar
NRE F-Bomb:
Well, the NRE set up would be the **** for sure. But I see no reason at all to spend $55,000 (installed) for the 427ci TT (1,850 hp) OR $65,000
(installed) for the 454ci TT (2,300 hp).
I already have an LSX iron block and my builder here builds huge hp turbo engines all the time for drag cars.
He's gonna do a 408ci LSX and hopefully when I finally get an answer on the OFI questions, it'll except a 101mm turbo. Or possibly the new turbo that Dr. Turbo is talking about will fit with the OFI current kit.
I'll spend half the money for the same power and my builder will be 5 miles from my house instead ~2,300 miles away.
I wish I knew what power the S91 would make on a 408ci.
Old Nov 28, 2007 | 11:35 AM
v7guy's Avatar
I believe the real measurement of horsepower is really CFM. It's why you see so much variation (in power)ibetween setups. It's the same N/A or FI. A blower/turbo/piston is going to be capable of pulling/pushing more air through a well flowing head and intake than it is through a restrictive head or intake.
Shouldn't we be judging the size of a power adder on the motors CFM?
Old Nov 28, 2007 | 11:36 AM
  #32
smokinHawk's Avatar
more then you could control.
Old Nov 28, 2007 | 11:37 AM
  #33
LS1Tech Co-Founder
1200-1400 hp would be my guess.
Old Nov 28, 2007 | 11:52 AM
  #34
Carnutz's Avatar
Ok well what AR would you suggest???
408 ci LSx ~8.5 to 8.7 to 1, L92 heads, GMPP single plane with an elbow. Cam is up in the air, Im guessing 230ish @ .050 ~ .600 lift Hyd roller.... TH400......
Old Nov 28, 2007 | 11:57 AM
  #35
DrTurbo's Avatar
LS1TECH Sponsor
Geez with that size setup....the biggest we offer for the S91. The S91 should do over 1200+rwhp.....or more then enough to get REALLY stupid on anything other then a full blown slick on a prepped track.
Old Nov 28, 2007 | 12:07 PM
  #36
tt427ls1's Avatar
LS1TECH Sponsor
I would go witht he S-91 and call it a day. I have customers running low 9's with a s-88 and a 408 and 402. When the new turbo design come out then I will see if that will fit. Im pretty sure it will fit. Im getting specs on it soon. So I will know shorlty. If you go with the s-91 now..im pretty sure you wouldnt have a proplem selling it if you need to.
Joel
Old Nov 28, 2007 | 12:18 PM
  #37
DrTurbo's Avatar
LS1TECH Sponsor
Joel
Yeah the S88 in a 3300-3500lbs car should get you low 8's and S91 should squeak you into the 7's. Of course you'll have to be on your game to get there....
Old Nov 28, 2007 | 12:25 PM
  #38
Carnutz's Avatar
Im looking to go high 7's and its a well prepped car with the required safty equipment.
Its geting a whole bunch of CM tube next week..........
Old Nov 28, 2007 | 12:39 PM
  #39
mahhddgtp's Avatar
Indeed.
Is there a set of twins someone has used on a LSx setup that compares to the numbers the S88 or S91 puts out for the same CI motor?? Beats?
Old Nov 28, 2007 | 12:53 PM
  #40
Quickin's Avatar
The OFI kits are 5 weeks out if you order now. Are the S91's available right now or is there a wait on them too? Whats the price?
