Is a single gt4294 too much?
Very true, part of the reason why we build units from all 3 manufactures and then some. Some just work better in certain applications.
I do think the common perception of kit design focuses far to much on this number or that and not enough people take a holistic view of their design and balancing the system. A well designed system should be greater than the sum of it's parts.
But I can't see how anyone can say BW's Extended Tip turbos don't own all. It's all in it's performance and on paper. 74mm BW will flow 120lbs/min at max potential. That outflows even the best of the GT42 series turbos... which are 76mm (I think).
Then if you want smaller. Their 56mm can flow up to damn near 65lbs/min!!
That thing should push another 4-5psi as well.
My friend has a S256 in his Neon SRT. He makes 21psi @ 3k. My other friend has a GT3582r and makes 20psi @ 4k. The GT3582r flows @ 61lbs/min. The S256 flows at 58lbs/min!! I think that's just crazy... BW FTMFW!!
You will love our FI58 then when its released. It will be in a small package as well and flow 62lbs/min, and also in BB and water cooled if you like. Or you can move up to our FI62 which will be offered in BB as well and flow 72 lbs/min....lol
Nobody has matched the performance of our S-series and selection availability with the BW's. Now the new FIXXX units bring it to the next level in customizing and new options.
DrTurbo, do you have any compressor / turbine maps I could look at, so I can see what everyone is talking about?
Just a basic turbo kit otherwise. Nothing special
