Is a single gt4294 too much?
Old Nov 29, 2007 | 05:17 PM
  #41
70Stang's Avatar
Originally Posted by ChrisUlrich
The kit is close enough. To be honest... the manifold on the S256 is supposed to be crap compared to the make on the GT35r setup. AND... the GT35r had aftermarket cams in it while S256 was stock.
Just a basic turbo kit otherwise. Nothing special
They make the same hp? Same intercooler size? You don't think the cams have any affect on spool? Downpipe is the same? Exhuast is the same? TUNE is the same?
Old Nov 29, 2007 | 05:33 PM
  #42
DrTurbo's Avatar
LS1TECH Sponsor
Originally Posted by 70Stang
So, do you have any actual DATA that compares spool time on the same car with the two different turbos? On the neon thing, is it the same turbo kit and everything?
DrTurbo, do you have any compressor / turbine maps I could look at, so I can see what everyone is talking about?
Our comp maps for the FI units are below.....
Attached Thumbnails Is a single gt4294 too much?-fi56.jpg   Is a single gt4294 too much?-fi58.jpg   Is a single gt4294 too much?-fi62map.jpg   Is a single gt4294 too much?-fi66map.jpg   Is a single gt4294 too much?-fi70map.jpg
Old Nov 29, 2007 | 05:37 PM
  #43
hellbents10's Avatar
LS1Tech Sponsor
Well as i stated I did not say one unit was the end all bad ***. I stated that I have had real world results and numbers at the track and dyno with a few different vehicles. No opinions just facts. I would love to compare a Bullseye unit vs. a FI unit though. I would put results up for everyone to see. I love both companies and the people who I talk to at both places. I just get a lot of vague answers as far as what they both do to the units. As I should, they are trying to be competitive after all. Dr. Turbo if you could send me your 74 I would try it and post results within a week and send it back. Or keep it if it and pay for it if it put up better numbers.
Old Nov 29, 2007 | 05:40 PM
  #44
ChrisUlrich's Avatar
Cams increase spool time.
Intercooler size is very similar. PSI-FI piece for Exhaust Depot piece.
S256 has a 3" DP but 2 1/2" all the way back.
GT3582r has 3" all the way from turbo.
Tune is just a piggy back. AFR. Tuned by same guy on same tuning setup.
Any other questions to try and disprove my theory?
  #45
DrTurbo's Avatar
LS1TECH Sponsor
Quick look.....
GT4088R - 63.5mm inducer compare to FI-62 which is 61.51mm
GT35R - 61mm inducer compare to FI58 which is 57.89mm
GT40 - 65mm inducer compare to FI-66 which is 65.3mm
Old Nov 29, 2007 | 08:35 PM
  #46
NA$TY-TA's Avatar
I for one wasn't impressed with the GT42-76. We couldn't get it to make more then 13 psi. Ran it at the track and that was all she had. Went back for the 2nd outing and the damn compresssor wheel hit the housing. Called up precision and had it sent back and they didn't want to warranty it. They finally did. I wasn't impressed with them at all. Swaped it out to the S88 wick is an exact match and nothing needed to be changed for it to work. Ran 1 1/2 sec faster @ 9 mph faster with 3 psi less boost. If had awsome results with BW from FI. I'm trying a few others for them and if they do what they say they will do its going to be an awsome new yr. I've used and still have other products from Precision. Maybe I just Got a bum turbo. I guess it was the customer service I wasn't impressed with.
Kyle
Old Nov 29, 2007 | 08:54 PM
  #47
LS1Tech Sponsor
Right on Kyle, pretty much any one with some cubes that has used a 42 or even a 47 chassis know they get backed up quick for their size.
Old Nov 29, 2007 | 09:19 PM
  #48
frcefed98's Avatar
I would like to see a untouched BW S200, S300, S400, go against both the FI.com units and the bullseye turbo's too.
Be fun to see where the baseline starts for these "hopped" up BW units.
Old Nov 29, 2007 | 11:34 PM
  #49
Willem @ Fuel Injection Concepts's Avatar
Originally Posted by ninetres
See:
lol
Not bashing any other Sponsors as they are regarded as stand up guys but that doesn't = gospel
Old Nov 30, 2007 | 12:11 AM
  #50
Broke EF's Avatar
What would you think of the GT42-76 with a .98 A/R on a stock 6 speed LS1? Im just wondering how you think it will do with smaller cubes. What about on a forged bottomend Iron block 6.0 motor?
Sean
Old Nov 30, 2007 | 12:28 AM
  #51
NA$TY-TA's Avatar
Sean
Sean my reply above was with a 370ci motor. So 6ci biiger then a stock 6.0L
Kyle
Old Nov 30, 2007 | 01:27 AM
  #52
chuntington101's Avatar
Originally Posted by DrTurbo
You will love our FI58 then when its released. It will be in a small package as well and flow 62lbs/min, and also in BB and water cooled if you like. Or you can move up to our FI62 which will be offered in BB as well and flow 72 lbs/min....lol
i know for a fact there are a good few Evo guys that have their eyes on these turbos. cant wait to see the performance gains over the Gt units. and if there is a chance that they will be smaller in physical size then could you have something to match the GT4202 thats doesn't require smaller rad?
also what the major advantage of the FI units of standard BW units??
thanks Chris.
Old Nov 30, 2007 | 08:14 AM
  #53
70Stang's Avatar
DrTurbo, thanks for the maps, I will look them over this weekend.
Old Nov 30, 2007 | 10:43 AM
  #54
DrTurbo's Avatar
LS1TECH Sponsor
thanks Chris.
The major advantage will be size, weight, quicker spool, endless selection of covers, A/R's,,,etc,,etc.
These units will bring you the latest ETT tech, but without the cumbersome size of the BW chassis units.
Pretty much the same thing PTE has done for Garrett. GT42 shrunk to a 74/76GTS.
Old Nov 30, 2007 | 11:23 AM
  #55
52172's Avatar
I love my TC76 and it is very very small and makes plenty of power for street use and its polished. FI has a great price on them.
Old Dec 1, 2007 | 04:45 AM
  #56
PhatTonis's Avatar
drturbo, i'm looking to turbo my 2.8L 328is at some point in the future, was planning something sized around a gt30r or so, 400-450rwhp eventually i guess...does FI make anything that size?
Old Dec 1, 2007 | 05:13 AM
  #57
valiant65's Avatar
Thank you for that. I would have said it too. We are using a 74mm BW unit on a GTO. Spools at 3k and makes big power at low boost levels and does not make so much hot air.
Which kind of turbine side? I was thinking of using basic S475 with T6 1.10 a/r turbine on my 346 ls1 and T56. Would it be too restrictive and should I go to 1.32 a/r housing, after all I'm searching for early spool for good street manners and max rpms at 6500 and at the same time economical cruising...
Old Dec 1, 2007 | 08:53 AM
  #58
DrTurbo's Avatar
LS1TECH Sponsor
For that power range a standard TO4E-50 would easily make 400rwhp on a 2.8L or GT30R. The FI56 will easily make those #'s as well, but might be a bit overkill for just 400-450, but it would definitely leave you some room to grow!!
Old Dec 1, 2007 | 08:55 AM
  #59
DrTurbo's Avatar
LS1TECH Sponsor
What kind of power are you looking for??
Sounds like a TC76 would be a better fit for your setup.
Old Dec 10, 2007 | 10:47 PM
  #60
We build and recieve units from all the big three and keep a massive spreadsheet on failure rates. You would be suprised at the results....
Way too many factors there to post a comment like that...
