5inch down pipes
Old 01-04-2008, 12:22 AM
  #61
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
^ Any more details on that setup?
Old 01-05-2008, 10:36 AM
  #62
candidate zero's Avatar
That's y2khawk's car. I'm sure you could search and find more info.
Old 01-06-2008, 01:40 PM
  #63
z28adiction's Avatar
Hey guys sry but thsi question is a bit off topic. But what kind of hood is on the red camaro, and where can you buy it thanks
Old 01-06-2008, 01:57 PM
  #64
SSilverSSurfer's Avatar
that car is red. its tom kempfs.
harlans car is black
Old 01-06-2008, 02:03 PM
  #65
RDTA's Avatar
Originally Posted by KissMySSo1
outlaw where did you get your aluminum 5" piping and bends from?
there is a few places in this thread listed.
https://ls1tech.com/forums/forced-induction/837015-aluminum-downpipe.html
Old 01-06-2008, 02:06 PM
  #66
slick1851's Avatar
Might I suggest people doing this have a clear bra put on the side of there car to protect the paint?
Old 01-06-2008, 02:35 PM
  #67
otherwhitemeat's Avatar
Thanks what I'm trying to tell people.....it's a bad idea for anything but a race car..
Old 01-06-2008, 11:51 PM
  #68
Oops. He posted em, and I assumed it was his. I stand corrected. Either way it's a killer setup.
Old 01-08-2008, 01:15 AM
  #69
bigsticksupra's Avatar
i don't think the red camaro is tom kempfs car.. isn't his single turbo with the raised SS type hood?
i think those cars are baddass, i always see 'stock bodied' mustang racecars with twin turbos but not f-body's often
Old 01-08-2008, 08:17 AM
  #70
The Bull
DERTY's Avatar
There are two red cars shown. To clear the air, the red car with the slicks on the back and the twin turbos in the nose is Rob Golobo's car. The red car with the 5" down pipe above the k-member is Tom Kempf's Red Rocket. Harlan did get the down pipe to fit with the high clearance BMR piece. When Tom parked the car in the wall at Norwalk it messed up that K-member so bad that we put his original ARE K-Member (no one makes these any more) back in the car. We did modify the down pipe to fit and it does fit with what basically amounts to a k-member that most people would have.
Ideally if we had Toms turbo on the driver side the pipe would have been a straight shot. Originally we only ran a small downpipe that pointed at the ground under the hood. When the rules changed we moved it to exit behind the front tire. We can interchange the two different down pipes pretty easily.
Old 01-09-2008, 01:38 AM
  #71
KissMySSo1's Avatar
where do you guys find your 5" aluminum pipng? and whats the thickness of the stuff you use?
Quick Reply: 5inch down pipes
