help me to pull zo6 c6
Old Dec 9, 2007 | 12:51 AM
98turbls1's Avatar
Originally Posted by ChevyChad
Fast/ cheap/ reliable:
Pick two!
exactly!! dude I've been THROWING money into my car steadily now for the past 2.5 years and I'm just now getting it to where i want it to be... I still have to get a rearend and shortblock... I spent a lot of money on my Th400 conversion because I went with good parts and I try to do everything I can the best I can because I hate doing it twice... Try to get a used procharger headunit, bracket/pulley system, go buy a FMIC kit, bypass valve, get some injectors, tuning, and some springs... That'll get you there for a while and then start tackling one part at a time.. that way it'll eventually get done and it'll motivate you to do more... Oh one more thing, DON'T COUNT HOW MUCH EVERYTHING COSTS... it'll **** you off...
Old Dec 9, 2007 | 01:17 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
$7000.00 won't do it. And thats a promise. Unlimited budget is what u will need.
Old Dec 9, 2007 | 01:44 AM
Hennytime's Avatar
cam only/boltons/3600 stall/150 shot/racetronix pump and some good tires and suspension to make it stick
searc ha guy named gm muscle, he ran a ms3 and 225 shot with lots of weight reduction, stock 2.73 gears in a ten bolt, stock heads and intake and stock tranny with a stall he ran a 10.1@135.
also a local guy ran a 10.4@128 wit ha hotcam, bolt ons, suspension, good tires and a 200 shot...
Old Dec 9, 2007 | 05:34 AM
eminem1833's Avatar
what about the full cost of STS with 8psi??
Old Dec 9, 2007 | 08:04 AM
LS1vazquez's Avatar
I dunno dude, you may be able to spend 7G's and pull a C6 but it isn't going to be a Daily Driver anymore.
Cheap
Fast
Reliable
Pick two.
Old Dec 9, 2007 | 08:05 AM
LS1vazquez's Avatar
Originally Posted by eminem1833
posted Today 5:34 AM
Holy **** dude, did you sleep?
Old Dec 9, 2007 | 08:43 AM
BOONE's Avatar
A budget and forced induction just dont belong in the same sentence. You simply cant afford it. Reference the posts of the people that have done it and listen or you will just waste a lot of time finding out yourself, and then having to go a different direction and starting all over.
Old Dec 9, 2007 | 12:39 PM
Zeke34's Avatar
I was bored and figured I'd help you out a bit by checking out the Classifieds section. Below are the links to the deals I found; one of the kits on there I've never heard of but as far as the APS & Gen TT Turbo kits go, just be aware of the fact that you'll need a bmr k-member. Thunderracing, Byunspeed and Exotic Performance Plus sell these as well as price match. I hope these links help you out in some of way and hopefully we'll see one of these kits installed onto your car. cheers
Procharger
https://ls1tech.com/forums/showthread.php?t=822816
Gen TT Kit
https://ls1tech.com/forums/showthread.php?t=782876
APS Turbo kit
https://ls1tech.com/forums/showthread.php?t=821456
Some Turbo Kit w/just about everything you’ll need
https://ls1tech.com/forums/showthread.php?t=819082
Vortech Supercharger
https://ls1tech.com/forums/showthread.php?t=821249
STS Turbo Kit
https://ls1tech.com/forums/showthread.php?t=809312
Old Dec 9, 2007 | 01:02 PM
Gary98Z's Avatar
You can get into FI for less than $10k, but you still won't be able to beat a C6 Z06, let alone a Z06 with bolt ons (if I read your message correctly). I seriously doubt I could beat one in a roll race, and I have ALOT more than $7k in my car. Due to their superior aerodynamics and light weight, simply matching their hp won't be enough. I think they can easily get 550rwhp -600rwhp with bolt ons and a cam.
You have to remember that it will take more than just bolting on a supercharger or turbo. In order to do it right and run high enough boost, count on spending well north of $15k. Upgraded tranny, forged internals, fuel system, torque convertor, tuning, h/c, headers, blower/turbo, FMIC, labor, and tons of miscellaneous stuff.
My advice would be to go with bolt ons, torque convertor, cam, and a big shot of nos. Of course, your tranny will probably crap out on you at that point. Your motor could last for a while with a safe tune, but anything could happen when you factor in nos or FI.
Good luck.
Gary
Old Dec 9, 2007 | 02:23 PM
2002camaroSS's Avatar
Idk about running that fast with a stock tranny and rear end. If you did manage that it wouldnt stay together very long. My buddy blew the sh*t out of his rear end when he was running deep in the 11's I couldnt see the tranny and 10 bolt holding up that long if you did get it to run that fast. I would invest in a tranny and rear end first and run a stock short block with nitrous and of course bolts ons and heads and cam. And why roll race the vette? The way to make it to your advantage is to race from a stop especially if you can get your car to 60ft he wont have a chance then seeing as those things spin like hell. O and force induction is very expensive i dont recommend going that way i have a lot of money in my turbo setup. And say you were going to only spend 7k you would kill all of that money just to get a turbo kit. And what a built rear is 2200, tranny 2500 and then you have the rest for nitrous kit, heads cam, and fuel system.
Old Dec 9, 2007 | 03:26 PM
Zeke34's Avatar
A nitrous setup wouldn't be a bad idea neither, there are an *** load of kits for sale in the classified section and not to mention, you'd be able to get a sweet *** deal on an entire kit along with supporting components from the sponsors :coughNitrousoutletcough:.
Old Dec 9, 2007 | 03:38 PM
  #32
DuronClocker's Avatar
I just happen to be getting out of nitrous and going FI. I've got a bunch of stuff *cough* complete kit *cough*
Old Dec 9, 2007 | 04:41 PM
  #33
Dragframe's Avatar
If i was gunna take a alternative route to how I went about my turbo kit... i could have done a forged bottom end with a DIY turbo kit and been in the 600 area for 7k. This on my LT1. A couple corners would be cut but it would still work well.
But that leaves any chassis work still not done including rear end and tranny. But that would take care of the power problem. So 7k spent in the perfect spots will get you power. But requires a lot of personal work and leaves the rest the car to deal with the motor.
Old Dec 9, 2007 | 04:49 PM
  #34
It'll get you the power, but like you said, you'd have to be cutting corners, and cutting corners cuts reliability/safety. The Camaro is his daily driver. If he has nothing else to drive (we don't know if he does or not) and something breaks because he bought a cheap part...where does that leave him?
Like the old and boring saying that was used above... Fast, Cheap, Reliable...pick two.
Just get into it slowly. Buy this, buy that, parts here and there at a time to slowly make power or build the car to handle the power first. For someone that can't type a complete sentence or has any idea what correct spelling/grammar is, I think going to ~300rwhp to ~600rwhp in one jump might be somewhat dangerous anyways
Old Dec 9, 2007 | 04:57 PM
  #35
LS1vazquez's Avatar
Okay I'll just come out and say it.
Your not dragging a C6 ZO6 with 7K in mods.
Even if you got the car to a point where theoretically on paper, you might be able to, the damn thing will probably grenade on you on the way up there or during the run.
There is a reason why those cars cost so much from the factory. Speed isn't cheap. I know Chevy has a lot of bang for the buck but god damn dude, get real.
Old Dec 9, 2007 | 08:05 PM
  #36
texada's Avatar
If you are racing at a drag strip you will need a Good set of heads, 230+ duration cam, LS6 Intake or fast intake, 3500 stall 3.73 gear and 100-150 shot of nitrous should net you low low 11's or high 10's around 125 or better. That should outrun the average C6Z on the drag strip. However, if you are racing on the street from a roll you will need something probally with a 150 more Horsepower than the C6Z. Supercharger with 10lbs of boost or stroker with a small shot of nitrous. I advise you to keep saving if you want to beat one on the street and strip.
Old Dec 9, 2007 | 08:52 PM
  #37
I can beat a C6 ZO6 all day... In my 07 R1 that is.
Old Dec 9, 2007 | 11:44 PM
  #38
badass99ss's Avatar
This guy did with nitrous and boltons, even the vett sprayed!
http://www.youtube.com/watch?v=WLkcUMzLCtA
........sweet vid
Old Dec 9, 2007 | 11:50 PM
  #39
ninetres's Avatar
Originally Posted by badass99ss
I dont know how to post links, but her is the web id.
This guy did it........sweet vid
Was the Z06 only sprayin in the 1st race or what?
Old Dec 9, 2007 | 11:53 PM
  #40
badass99ss's Avatar
I think the camaro didnt spray in the first race, thats why the vett pulled.
