regulator from 97 vette rails - vacum/boost regulated?
I am pretty sure it is but want others in the know to confirm or deny.
Is it both vacum/boost regulated or other?
Trying to verify if I am using that regulator/lines I flatline my IFR table with all the same values.
So you just connect a vacum/boost source off the intake manifold? I was under the impression you could only put boost to it. Ive been running mine with a one way check valve.
It is Vacuum ONLY!!!
In Vacuum it will reduce the fuel pressure, and in boost it will be completely open or max fuel pressure which is about 60psi.
If its an adjustable one take the vacuum line off and set the fp to 60psi at idle then reconnect the line. It will then pull or reduce pressure at vacuum and you will see 60psi when in boost.
Well then I stand corrected. Is yours an adjustable one with the set screw on it? What brand?
That was the way it was explained to me by the company that sold them, Eckler's Corvette Accessories. It could be they didn't really know
