turbo or procharger?
Old Dec 23, 2007 | 06:45 PM
johnnydje's Avatar
Question turbo or procharger?
this has probally already been answered,if so point me where to go.but looking for ease of installion,relaibilty,price,and of course power.looking at sts kits/procharger kit,not sure about the other ones,if somebody got answers i'm listening.thanks
Old Dec 23, 2007 | 06:49 PM
BLNLS1/RX7's Avatar
There is only one place you need to look.Exotic performance Plus.com.They sell and install more Pro Chargers and Turbos than anyone.Call Bob and he will be glad to answere all your questions.
Old Dec 23, 2007 | 06:55 PM
TS6's Avatar
TS6
Depends on your goals. For price, reliability, ease of install, and power, it sounds like an ATI kit is the best for you.
Old Dec 23, 2007 | 06:59 PM
Websy21's Avatar
ebay electric supercharger with a tornado infuser
Old Dec 23, 2007 | 07:51 PM
johnnydje's Avatar
basic power,but this a everday driver,in traffic,overheating?
Old Dec 24, 2007 | 04:35 AM
EPP's Avatar
EPP
The ATI ProCharger D-1SC is what I would recommend. Here is a total kit I put together that uses the ATI ProCharger D-1SC, and has an F-1A upgrade option.
http://www.exoticperformanceplus.com....html?item=798
You will see that I include the required harmonic balancer and crank pinning kit, 60lb fuel injectors, Walbro fuel pump and we supply a tune.
Here is a list that I put together that may help you.
http://www.exoticperformanceplus.com....html?item=540
As far as everyday driving goes, the supplied fan from ATI ProCharger will sometimes not be enough if you live in a hot climate. Adding this fan makes a difference. http://www.exoticperformanceplus.com....html?item=729
Here is a Trans-Am from El Paso, Texas that we added this fan to.
http://www.exoticperformanceplus.com/hotCars.php?car=62 Bob
Old Dec 24, 2007 | 04:42 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
If you are going the Procharger route then Bob at EPP is all you need. He will answer all questions with no sales pressure for you to make a purchase. Believe that.
Old Dec 24, 2007 | 04:59 AM
EPP's Avatar
EPP
Thumbs up
Thanks, I appreciate it! Bob
Old Dec 24, 2007 | 10:59 AM
johnnydje's Avatar
hey bob,johnny,i will be calling you after the holidays,just wanted to put it out there,is there anything wrong with the sts systems,looks fairly simple to install,not sure about ground clearence/subframe connectors working?have you messed with any of these sysstems?
Old Dec 24, 2007 | 11:06 AM
Websy21's Avatar
Ok you obviously didn't get it, the electric supercharger was a joke. Don't **** around with sts, call bob and be done. Buy the D1 kit, for stock cubes this is all you will need for sure unless you want to push the envelope but doesn't sound so to me. Its the most basic, reliable, cost effective, complete kit you can buy on the market. Buy it and have fun!
Old Dec 24, 2007 | 11:08 AM
platinum1's Avatar
i find the sts kit does not produce enough power for me anyway!
Old Dec 24, 2007 | 11:27 AM
johnnydje's Avatar
yea i got it,just asking,thanks though websey21,yeah i'm calling bob.sounds like a procharger will be coming!thanks guys
Old Dec 25, 2007 | 06:02 PM
johnnydje's Avatar
hey bob,heat among the procharger itself? IET?is it a problem?
Old Dec 25, 2007 | 08:05 PM
Jake@EPP's Avatar
The ATI does not add much if any under hood temps compared to a turbo setup.
Old Dec 26, 2007 | 12:20 PM
pwrtrip75's Avatar
if you drive your car often, the procharger noise will make you want to kill yourself.
Old Dec 26, 2007 | 12:48 PM
Spoolin's Avatar
Originally Posted by Websy21
Ok you obviously didn't get it, the electric supercharger was a joke. Don't **** around with sts...
Why?
Why? how much are you trying to make?
Old Dec 26, 2007 | 01:04 PM
geeteego's Avatar
Originally Posted by Spoolin
Why?
I kinda chuckled when I heard that too.
Old Dec 26, 2007 | 01:13 PM
Spoolin's Avatar
He's comparing a Procharger vs. a STS, not a front mount turbo.
Between the two mentioned the Procharger would add more underhoot heat than an STS would.
Old Dec 26, 2007 | 04:50 PM
Jake@EPP's Avatar
Might ad just a little, but for the lack of head aches and a simple bolt-on kit, it is far worth it.
We had a customer a while back get the base STS kit, well then you tack on a IC kit, and then fixing all the "silicone" fittings they send, your well over a ATI setup. The oil system from STS is quite a joke, sending it back into the oil cap is not the correct way to run the return, welding a bung into the pan or timing cover is.
For the amount of money this customer put into his car after modifying the kit to break 600hp, and then break 700hp, he would have been able to break 900hp on a ATI setup.
My suggestion, the STS is defiantly a stock motor kit, any more and you might as well get a front mount turbo setup, as you will have that much into it.
There are a few rear mount cars that are defiantly fast and make big numbers, but they are setup for doing just that, if you have to ask how much they have in it, most people cannot afford it.
Old Dec 26, 2007 | 05:01 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I disagree! I LOVE the whistle!
