Aftermarket MAF
Old Dec 25, 2007 | 12:33 AM
badass99ss's Avatar
Default Aftermarket MAF
Are you guy's with fi running aftermarket MAF's? I'm going to be installing a procharger and a 90mm FAST intake along with a 90mm NW throttle body, will I need to run a larger MAF?
Old Dec 25, 2007 | 12:35 AM
ninetres's Avatar
Ditch that fugger all together and run a SD tune. If you must run a maf, stick with the stock one or a GM 85mm from a Z06.
Old Dec 25, 2007 | 12:56 AM
badass99ss's Avatar
Sd tune???? After I get the car together I will trailor it to get dyno tuned, can they do what you speak of?
Old Dec 25, 2007 | 01:18 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
SD = speed density. Calibrate the computer to use either a 2 bar or 3 bar tune. Adjusts fuel, etc. based on boost, not mass flow rate... If you plan on running more than 15psi, you may as well do a 3 bar MAP.
Old Dec 25, 2007 | 01:30 AM
RooRnZ28's Avatar
stick with a GM one
Old Dec 25, 2007 | 12:17 PM
Floader's Avatar
+1 for stock GM
Old Dec 25, 2007 | 11:39 PM
badass99ss's Avatar
So it's cool if I don't touch it and run it the way it sits? F'in A cotton!
Old Dec 26, 2007 | 12:47 AM
blu00rdstr's Avatar
Will SD tune pass smog test?
Here's a big 102mm MAF - http://www.powrmax.com/powrMaf.html
Old Dec 26, 2007 | 04:44 AM
EPP's Avatar
EPP
I don't know of anyone who has had any luck with the aftermarket maf's. We have the stock one on this D-1SC lS1 engine producing 740 rwhp.
http://www.exoticperformanceplus.com...Car.php?car=40 Bob
Old Dec 26, 2007 | 12:32 PM
Big Bird WS6's Avatar
sd is stupid. just tune it with the maf sensor. there is is climate control no nothing with the sd tune. i know you can do good tunes with a maf sensor. buddy is running 23 psi throught a gm one. works fine.
Old Dec 26, 2007 | 02:45 PM
ChevyChad's Avatar
Wow- all you big boys running SD, you guys are going about it all wrong. Listen here, this guy has a buddy who...
Hey man, do you even have a FI car, or are you just trolling?
Old Dec 28, 2007 | 03:38 PM
who the hell deleted my new post.
